This fault won’t clear, and my cooling fans have been running a lot. I assume I need to replace the thermostat housing, which has this sensor…is this correct? Also, I would like to remove the connect and test before I rip everything apart. If this is a “short to ground” fault, then can I just do a continuity check across the terminals? Help appreciated.
001433 - Thermostat for Mapped Engine Cooling (F265)
P0599 - 001 - Short to Ground
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 236115 km
Time Indication: 0
Date: 2020.09.17
Time: 18:41:07
Freeze Frame:
RPM: 883 /min
Load: 52.1 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 55.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.176 V
Readiness: 0110 1101
