Hi there,
I am trying to fix the dreaded beeping accompanied by the ABS, ESP and Parking brake lights being on. From previous topics, it looks like the most common culprit is the ABS module, which I sent out to be repaired. Now, I have put the repaired ABS module back in and I have communication with VCDS, but now I have the above code and the same lights are still on.
From browsing the Ross-Tech forum, it looks like this could still be an ABS module issue, the ABS pump itself, or some issues with the actual pressure within the ABS system.
Does anybody have any experience with this code? I think I will try to bleed the ABS system again, and see if I can do anything through basic settings in VCDS, but other than that, does it sound like a new ABS pump is needed?
Thanks in advance,
Spencer
