With the car finally in hand, it’s time to start down that path
The good news - after the car was delivered, my brother was kind enough to take some logs and saw no issues (misfires, etc.) so the engine is nice and healthy 8) 8)
The bad - Today’s trip to the local VW/audi specialist uncovered items that were not noted during the routine dealer inspection provided by the seller. Lesson learned - always get a PPI. always.
Fixes Needed:
-Accessory Belt (immediate need)
-Crank Case Breather Leaking
-Oil Pan Leaking
-Water Pump Replacement
Bentley guide is on its way, and depending on how immediate and difficult the breather and oil pan are (can’t be that bad…right?) I’m pretty sure my brother and I could knock those out in a day or less. The water pump needs a lot of labor (~10hrs :o :o ) so it’s not for the impatient or faint of heart. I will probably end up leaving that to the shop.
As far as other mods/replacements go:
JHM Intake Spacers
Spark Plugs
Ignition Coils
Flow-matched Injectors
JHM LW Pulley
JHM Exhaust
Interior/Exterior Clean
Fix rock chips (Dr. Color Chip is seriously amazing if no one has ever used it)
All things in good time. Once the most pressing items are taken care of, I promise some really nice pictures
