Few Quick Tech Questions
Thought I would get some sage advice while I am logged in
  1. I am replacing my serpentine and crank pulley with the new JHM units, my question is, when I put my rad to service I only have about 4" to work with, is it better to just remove the rad altogether for the install or should I just leave it alone and fire in the new parts in the tight working conditions. The bentley actually does not call for complete removal, but it appears to be tight space to navigate! I also plan to do the seal as well while I’m in there.
I was using this http://www.cuccarogarage.com/diy-audi-b6-b7-s4-serpentine-belt-replacement-service-position/
The author appears to leave the rad on and endure the cramped conditions, when I looked at a few other build threads lately it looks like most people who have done this just pulled everything, but then again most were tossing on superchargers.
  1. I am replacing my lower control arms/balljoint, and the bentley references a specific VAG tool that apparently helps removal… any idea where to get one or if its worth picking up?
  2. Do any of you guys use anti seize on your hardware, if so what parts? I only ask because I am encountering a staggering amount of seized/corroded bolts. My rear sway bar bracket M10s actually snapped clear off when I went to remove them. I pumped the PB to it, hit the second bolt with map gas, and it still twisted off. >:( The 034 replacements appear to be stainless, but I am now fearing galling. :-\
