Finally found my perfect v10
Coming from the STG 3 2.7t nightmares, I am looking for a different style of money pit…
I was specifically looking for a V10 w/ ACC and a new intake manifold. Instead I got a new engine and Audi installed the old and broken original IM. Car has 120K, engine replaced at 60K, and I installed a new IM at 125K. ;D
Tech & Winter Package - CF Trim - ACC - Stasis SE12 20x9 - Michellin 275/35/20 - AMI w/ OE BT - 4610 MMI - C6 RS6 BBK w/ AP 390mm Discs - JHM Tune, IM Spacers, Heater and SAI Bypass - K&N Filters
Few weeks after I bought the car, nothing done but wheels:
https://i.imgur.com/x6b2Jcc.jpg
https://i.imgur.com/MlfmAvB.jpg
Many months after owning the car, repainted hood, bumper, fenders and paint correction rear 2/3rds car 3 times - Full Front suntek clear bra full kit:
https://i.imgur.com/NVmjlxg.png
https://i.imgur.com/69AUVti.jpg
Items I have done since purchase
Purchased new ACC heater plate. (Only to be used in Winter and swap out broken one for summer time)
Installed the 275s from my D3 - YES they Fit, I have about 6mm on inner front upright. Sorta never rub
4 oil flushes 118K - 126K
Replaced Fuel Filter - old one did not have dirt / sludge inside (good sign)
Headlight & LED strip & re-clear
Rear OE Rotors / Pads - 120K
Fixed ACC coding so it works
Updated to 4610 MMI
Installed AMI
Installed OE BT module for music streaming (4F0051510J) - Did not use USB Flash Drive Update!
New Front Filler plate - 4F0807285K1QP - Re-painted Phantom Black @ 125K w/ bumper
VCDS Tweaks: Windows Comfort, ROW Lighting, Seat Belt Chime, Backup Graphical Display w/ Camera
New OEM Coolant Reservoir - 121K
Brake Fluid Flush - 121k
New Spark Plugs - 121K
New Front BBK - Hawk HPS Street, C6 RS6 Calipers, AP Racing 2-Piece LW 390mm Rotors. - 123K
Amber Bumper Mod --> Black - 123K
2010+ Chrome Push Start - 123K
Front Sway Bar Bushings - 123K
New Battery - Northstar AGM Light Weight Size 48 “properly coded in w/ VCDS” - 123K
Replaced front drivers side axle with used OEM. (Busted the inner boot on original) - 123K
Replaced Drivers Head Light rear cover “no more condensation inside” - 125K
Replaced Washer Reservoir o-ring - 125K
Replaced all oil filter housing o-rings, figure 8 o-ring, PVC return flat gasket - 125K
SAI, kombis, solenoid, filter delete - 125K
Paint-corrected entire car. Clay, buff, polish, seal -125K
Sanded and professionally had the front bumper, filler plate, fenders, and hood re-painted -125K
Carbon Clean & dry fire w/ spark plugs out cleaned bores -125K
Replaced VVT Solenoid O-Rings - 125K
New Hitachi Injectors - 125K
New Intake Manifold - 125K
JHM IM spacers - 125K
Intake / Separator Heater Del - 125K
Cleaned radiator behind AC condenser & re-painted black with SEM flat black - 125K
Plastic Coolant T fitting replaced w/ brass from JHM - 125K
K&N Air Filters “fit like a glove” - 125K
New OE Serp. Belt - 125K
Clear Bra Full front kit - SunTek - 125K
Items to Do
Leatherique seats - asap while it is still hot out
Ceramic Coat Entire Car - likely never “mixed reviews”
PS fluid flush - need to figure out how to do so
Trans Flush - before this car sees a track will do
New Right Rear parking sensor - likely will never fix
Stage 2 / Phase 2 Wish List
Drop engine
Trans filter
Cat delete / headers
JHM Cat-Back
Coil Overs
Drivers Seat
Rear 2-piece rotors
Services Done Prior to purchase Full 12 page .pdf HERE
PS Rack and Servotronic Module - 4F1422052S - 2868 miles
5K Mileage SVC - Oil Change -6830 miles
15K Mileage SVC - Cabin Filter, Engine Filter, Oil Change - 17168 miles
Right Headlight Washer replaced - 4f0955102 - 19440 miles
Battery replaced - 000915105AK - 37946 miles
Low Fuel Pressure Sensor replaced - 06e906051k - 37946 miles
35K SVC - 37946 miles
Brake Fluid Flush - 44929 miles
Lower Intake Manifold motor replaced - 07L129086B - 45472 miles (removed radiator & re-install)
45K SVC - 45472 miles
All (10) Coil Packs replaced under “Recall” - 06E905115E - 55874 miles
PCV / Oil Seperator replaced - 079103464D - 62549 miles
Drivers Side Window Switches replaced - 4f0959851g - 62549 miles
Engine replaced (and everything else required for this repair) - 07L100031AX - 63290 miles
Water Pump replaced - 07C121599A - 63290 miles
Water Pump Hoses replaced - 4F0121109AD & 4F0121109AC - 63290 miles
Vacuum System Line replaced - 07L201935 - 64989 miles
HPFP replaced - 07L127026A - 65153
Carbon Fiber Trim Front Left replaced - 4f0867410M - 67152
Carbon Fiber Dash Trim replaced - 4f0867410M - 67152
ECM Power Relay replaced - 4h0951253 - 71675
Battery replaced - 000915105D** - 86119 miles
Front Passanger Air Bag recall - 110739 miles
(appears to be some missing maintenance records from 87K - 110K…)
As with all old audis, gotta do the headlights. Sand w/ 400 --> 800 --> KwikClean --> Tack Cloths --> (4) coats of US Chem Clear 2K Aerosol Spray. Turned out perfect
https://i.imgur.com/65TVatE.jpg
New Coolant Resevoir installed @ time of spark plugs ~ 121K:
https://i.imgur.com/x7uYHkP.jpg
Polished Tips. Tips were completely brown/black. Honestly my FAVORITE about these classic S cars are the staggered/ off-camber, oval tips. When I re-do exhaust, I plan to use the same tips for the OE feel
https://i.imgur.com/Ky0PInM.jpg
Next, The rear rotors were shot!!! I bought the car during the dark and actually put about 400 miles on the car with the rotors like this. Scary… Front are fine
OLD:
https://i.imgur.com/bigXKlW.jpg
New:
https://i.imgur.com/ZRgjNlP.jpg
https://i.imgur.com/Qovy350.png?1
While I was at it I figured since the brakes looked like this, I wonder what the oil looks like… Well here is a picture of the oil coming out after the SECOND FLUSH. It is currently on its third change in 100 miles and starting to look like oil again.
Doing 5 full flushes with the Rotwella T6 prior to moving toward my A3/B4 Castrol Euro Oil w/ some BGMOA
https://i.imgur.com/HmQKzNT.jpg
Oil now looking better on 3rd flush:
https://i.imgur.com/JxAvX20.jpg
