Love it bud. I think your going to love it more if you already don’t have the JHM tune. You will notice that it changes the tone even more.
IF you don’t mind I copyed this for those that will end up asking.
TO clear up the question which many have been asking “will it fit?!?” I also installed my Milltek DP’s which I took off my old b6 s4. Soooo here’s my current mod list and future mod list as well as some pics and a write up on the Magnaflow catback.
Magnaflow RS4 catback
Milltek catless downpipes
PICS!
how last weekend began:
http://i889.photobucket.com/albums/ac97/bud8817/2203.jpg
http://i889.photobucket.com/albums/ac97/bud8817/2204.jpg
(Catback is out!)
http://i889.photobucket.com/albums/ac97/bud8817/2205.jpg
And now its time to run into some fitment issues. As you can see form the images below the Milltek DP’s and the MF CB didn’t want to mate up to well. I ended up having to cut an inch of tubing off the down pipes so that the catback would sit under the car right. As far as I know this is not something that needs to be done if you have stock DP’s, I’m assuming that the Milltek DP’s are slightly longer(?).
http://i889.photobucket.com/albums/ac97/bud8817/2209.jpg
As you can see in this picture the DP closest to the camera has been cut and the the one further away hasn’t been.
http://i889.photobucket.com/albums/ac97/bud8817/2210.jpg
I needed slightly longer bolts for the stock sleeve which connected the DP’s and the CB. The sleeve had to be expanded in order to connect the two. This was not a big issue, and it ended up sealing up quite nicely. Here’s an image of the bolts I bought to accommodate the expanded sleeve.
(stock on the right and new longer bolt on the left, 4 bolts are required)
http://i889.photobucket.com/albums/ac97/bud8817/2216.jpg
So then we come to the biggest issue of the Magnaflow rs4 catback. Apparently the RS4 rear valance opening are a bit wider than the S4 openings. The tips were sitting approximately an inch too far outward when sitting in the hangers normally. So I improvised; all I needed was 6 hose clamps, three for each hanger. This pushed the mufflers inward and made the tip sit perfectly inside the valance openings. I do not think this put any stress on the catback in any way and frankly I think it worked out great!
Passenger side:
http://i889.photobucket.com/albums/ac97/bud8817/2217.jpg
Driver side:
http://i889.photobucket.com/albums/ac97/bud8817/2218.jpg
http://i889.photobucket.com/albums/ac97/bud8817/2219.jpg
How they line up (I got rear ended [=(])
http://i889.photobucket.com/albums/ac97/bud8817/Clipboard01-2.jpg
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks018.jpg?t=1311648286
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks017.jpg
And some pics of the entire car! [:D]
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks020.jpg
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks019.jpg
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks016.jpg
http://i889.photobucket.com/albums/ac97/bud8817/markscarpicks014.jpg
