So I have not dove into this much, but was considering putting my borescope into the hole where the starter is after I remove the starter to see if any fluid is inside or dripping from the back of the motor or around the TQ.
Mind you the engine has 70k on it so doubtful it is the rear main seal but it could be. Also the PS lines were wet, maybe this could be PS fluid.
The drips and leak are not wet, but the are sticky and appear to be “old leaks” or could simply be motor oil from when the figure 8 orig on the oil cooler was bad causing oil to drip down the front and back of the engine
I was thinking I could drain and fill the ATS and Front /middle Diff fluid and see which has less fluid and identify that way. I am trying /hoping I dont need to seperate the trans from the engine
You can see no fluid is on the engine, the seam where the trans bell mates with the engine, there is ZERO leakage on the engine. Possibly when audi replaced the engine they left the dirt, grime, and old leak residue from old problems on the trans and simply mated the new engine and reinstalled without cleaning?!
I think that these leaks are from the ATF and diff coolers
