Ok, got reman inner CVs installed. Waiting on spring clamp tool two days longer than expected (thanks, Amazon! :
http://audirevolution.net/addons/albums/images/705633237.jpg
http://audirevolution.net/addons/albums/images/529.jpg
Had to break down and get some help from the dealership on the pinch bolts. I tried and tried, but to no avail. I soaked in ATF/acetone, and tried using the air hammer…no joy. Figured they do them all the time, have the tools, and would be responsible if they screw up. Cost me $400…ouch, but they are done.
http://audirevolution.net/addons/albums/images/809564455.jpg
They said they soaked them upside down in a gallon pail of liquid wrench, then drilled the centers out, and finally pressed them out. The pinch bolt is a little loose in its bore, so I hope that is ok. The control arm ends are very tight, and I suppose that is what matters. I am assuming that the clamping load applied by the pinch bolt is sufficient to prevent the ball joint from moving relative to the housing.
Anyway, this is where I’m at right now:
http://audirevolution.net/addons/albums/images/863724844.jpg
At this point I’m degreasing the trans area (leak from somewhere…hopefully not trans?). Already cleaned up the oil pan, which looks to be leaking around the rear flange. Confirmed weeping coolant leak from water pump…some crystallized coolant evident.
I’m also going over the subframe and spot treating any rust with POR15. Already sanded down and repainted one end of the front stabilizer bar, which was pretty rusty from where the powder coating got scraped off.
I’ve got to say I’m appreciating the build quality on this car. As an example, everything seems to be powder coating rather than painted. Fastener plating is outstanding. This car has seen 9 harsh midwest winters and is holding up quite well.
