Front control arms, shocks and axle boot replacement
I’ve almost finished gathering all the parts I need. Shocks should arrive Wednesday. Got around 102k miles. Want to keep the car at least 50-60k more (hopefully, longer?), so it makes sense to me to do this work now, rather than later, so I can enjoy the tighter ride instead of driving the car into the ground. The handling has been noticeably looser over the last 1-2k miles, and I know at least the upper control arm bushings are shot.
Will be replacing:
all front control arms and stabilizer links (using OE Lemforder)
front stabar bushings
Bilstein B8 sport shocks
front strut mounts; rear shock mounts
front inner axle boots
hardware for the above (new nuts, bolts, washers)
Quick question: there seems to be a few minor snafus with the hardware order (some missing bolts). But, also wanted to double check that I received the correct lower control arm bolts. The rear lower arm is 112mm from the underside of the hex head to the last thread (a bit too long?), and the front lower arm is 85 mm from the underside of the hex head to the last thread (no point at end and no shank…maybe superseded p/n?). Can anyone confirm that has this apart or has the old fasteners? (I ran out of daylight today, and won’t be able to get the underbelly pan off for at least a few days to try and measure myself).
I’m happy to post photos on my project or answer any questions along the way if that helps anyone. Found a lot of great info on this board and YouTube. (Won’t be able to get to this for 3 more weekends due to vacation and other time commitments though).
