FS: JHM Lightweight Rotors - B6/B7 S4 - Fronts
Asking $425 OBO
FOR SALE:
JHM 2-Piece Light-weight Rotors - FRONTS only
Here they are new on JHM’s site: Clicky
Notes:
  • I have not used them (came with vehicle, uninstalled), although they do visually appear to have some very minor use. I could not measure any material loss though.
  • I measured with calipers (see photos). They are at/above original thickness.
    Measurements
    (also see photos)
    Original Thickness: 1.18"
    Measured Thickness: 1.187" & 1.189"
From JHM Product Page:
Stock vs. JHM
-Rotor Weight: Stock = 25.5lbs(each), JHM = 16lbs(each) - 37% LIGHTER, 9.5lbs less each
-Rotor Cooling Air-gap: Stock = 9.5mm(.374"), JHM = 18.5mm(.728") - LARGER for better cooling
-Rotor Cooling Center Fin Design: Stock = Straight Fin, JHM = Airfoil - MORE EFFICIENT for better cooling
-Rotor OD: Stock = 345mm(13.6"), JHM = 345mm(13.6") - SAME
-Rotor Thickness: Stock = 30mm(1.18"), JHM = 30mm(1.18") - SAME
-Bolt pattern: - SAME (fits like an OEM rotor would)
-Each rotor weighs almost 10lbs less than stock for a total of almost 20lbs weight savings.) 37% lighter
Photos:
https://drive.google.com/open?id=0B8S1F84jJWW4U1FTcnVQS0ZQN3M
New are $625+shipping from JHM
I am asking $425+shipping. OBO!
Make offer!!
Text 989-370-1694 or Post/PM here if you have any questions or want more pictures of something. Send zip for shipping quote
