Having a fuel gauge issue where the fuel gauge won’t come off full until I’ve driven at least 150 miles, where it used to start to move at half that. Then it will only get to about ¾ regardless of how much more fuel is used.
Some background- took car for service, ran great, filled it up a few days later, and when I got home, fuel was leaking everywhere. Back to shop and they found bad fuel pump gasket, so it was replaced. Also replaced the lines going to the filter. Fast forward a few days, and the fuel gauge isn’t working. Bring it back again, and after almost 3 hours, the shop finds nothing, all sensors and the cluster are working as they should. Apparently, the issue might be with the siphon pump, which I’m not finding much information on.
Can someone help me understand how the system works, and if there is a way to test the siphon pump? Seems the fuel tank straddles the driveshaft and has to pump fuel from one side to the other. Any chance it could be the new fuel filter?
I also did notice a change in the sound of the fuel pump when I first picked it up, but I thought it was because of the new fuel filter.
Any help greatly appreciated
