fuel leak @ HPFP fitting
http://www.voidopolis.com/images/IMG_1928.JPG
So I found a replacement fitting for my HPFP (I had stupidly cross threaded the fuel line to the old fitting). Anyone know the torque spec for the fitting or anything you need to do “special” when installing these into the HPFP? Now I’m getting a leak between the fitting and the HPFP - not the fuel line and the brass fitting. The fitting isn’t sealed in some way is it?
on the reinstall, I was OH SO careful about getting everything lined up perfectly and only hand tightening at first before using a wrench on anything…
