Hi guys I keep getting this come up every now and then it normally happens at idle. But it’s been more and more lately in the last few days.
I know it’s an open circuit but I’ve checked all wiring and plugs around both HPFP and can not see anything ?
If I clear the DTC codes it disappears for awhile but has come up 3 times in the last 2 days ?
What am I looking at here a new HPFP ?
As I know they don’t sell the fuel regulator valve on its own.
Also what bank is it on 1 or 2 ?
If there is anything else you can think of I appreciate your help.
Where is the best place to get a new HPFP any info would be great.
Here is the DTC read out. There are no other codes at all.
Thanks again guys !
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 1B 22 30 42 44 46 47 52 53
56 5F 62 6D 72
VIN: WUAZZZ8K3EA901052 Mileage: 96350km-59869miles
04-Steering Angle – Status: OK 0000
14-Susp. Elect. – Status: OK 0000
15-Airbags – Status: OK 0000
1B-Active Steering – Status: OK 0000
22-AWD – Status: OK 0000
30-Special Function II – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
56-Radio – Status: OK 0000
5F-Information Electr. – Status: OK 0000
6D-Trunk Elect. – Status: OK 0000
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l JHM93 / H04 0005
Revision: NAH04— CVN: 34C1198F
Coding: 1225003225A6000A2000
Shop #: WSC 06341 128 28888
ASAM Dataset: EV_ECM42FSI0118T2907560E 001004
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E2539F490FB017B95D-806A
VINID: 9E546AAAA21B0D544900100508EC791BFC
1 Fault Found:
4608 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 96347 km
Date: 2021.10.22
Time: 15:05:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 84 �C
Intake air temperature: 45 �C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.203 V
Unlearning counter according OBD: 40
Engine status-Bits 0-7: 1
Engine oil temperature: 77.7 �C
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
Readiness: 0110 1000
