So an interesting/annoying phenomenon has popped twice in the past month or so. My car does not like lower gears (2-3) for extended periods say on slow winding mtn roads (been looking at new homes/property away from people). Twice now after periods of maybe 45 min - an hour the car just says nope I’m done and cuts out. If I let it set for a few minutes it will fire back up and on my way again. But, it will cut out again shortly after. Eventually after a couple cycles like this it acts completely normal and gets me home no problem. Also prefers to be level ground to rest and get going again (not always possible). Also, Plenty of fuel in the tank both times.
044 in tank pump. Normal noisy sound gets elevated during these instances.
Any ideas/helpful advice? Thanks. I need to get in the tank and make sure all is normal and see what’s going on. I did not install it. Came with the car from PO.
just bolt on stuff…lol.
