Thought I’d start my own thread to avoid threadjacking Axel’s
I finished breaking in my stage 4 clutch so I did a few pulls.
Basically feels like the clutch isn’t releasing fully. Still grabs hard though.
I did a pull a few nights ago, then fully let go of the gas and pressed the clutch all the way in and coasted. There was still some grabbing as the RPMs came down.
http://www.youtube.com/watch?v=WfAgDmO_-XE
Also, from a full stop when putting it in gear, the car kinda bumps forward or shudders. I can exaggerate the issue by doing an in gear pull to high rpms. This causes almost all the gears to be locked out until the car and rpms slow down. The issue is non-existant when the car is off - I can get into all the gears very easily.
The slave and master cylinders are new (USP) as are the lines. I’ve tried bleeding the fluid and have had no luck.
Short of pulling the clutch and everything out again, is there anything else I could check first?
This is my second JHM clutch. My first had been sent back for warranty for other issues. Both were broken in well past the recommended city kms. I do not ride the clutch or otherwise use it sloppily. Both had under 10 launches with launch assist (in fact I’ve only done two on the new one).
There seem to be numerous issues tracing back to the RS4 pressure plate with both stock and modified clutches. If I end up biting the bullet (again) and pulling the clutch, what other alternatives do I have?
I’d personally rather wait for this new stage 5R pressure plate from JHM if it’s not based on the stock RS4 pressure plate. But at the same time, I’d rather not drive with a clutch that isn’t releasing fully. I can control the minor wear on the clutch to a point by keeping it out of gear whenever the clutch is pressed, but this is putting some serious wear on my synchros.
I’ve been looking around at alternatives that don’t use the RS4 Pressure plate. The clutch masters kits had some issues. The Spec kits seem ok. And the Sach’s kit seems to want you to use their flywheel.
I still have my stock pressure plate and clutch lying around too. I must have done around 50 launches on that thing and had no issues where the clutch didn’t release fully.
Anyways, forgive my ranting. What do you guys suggest the next step should be?
