West - thanks for the tip. I had considered sphericals, but being a dd + I am in Canada with bad winters + salt, I didn’t want to deal with the whole spherical thing. It’s clear from my setup that my car is a compromise setup–with the priority being daily drivability. I am happy to make that trade off. I’m going to Canadian Tire Motorsports Park (aka Mosport) in a couple weeks. I’ll report back on how she does at a real world class circuit.
Drob - Yup! I do normally run SRF, but my SRF source just disappeared, so it’s not easy to find locally at a decent price. I have one bottle left that I was saving–and it looks like I’ll have to use it now (since my fluid is cooked). I may run those TI backing plates. They do WONDERS, but at the expense of a dramatic increase in pad fade with little warning. So it can be a safety thing in some situations. In all honesty, I’d rather deal with a soft pedal (or even the pedal going to the floor) because at the very least, I know my pads are still there. I just brake check on the straights periodically for pedal pressure. Pump the brakes when it goes to the floor. Worked for me last season anyway
Very glad to hear the Z2’s are working out for you. They continue to be my favorite street tire. Very responsive and wakes up the front end of this car. That said, you may find the slip angles to actually not be as forgiving once you turn off TC. There is a very small envelope of grip for these tires. Exceed that and they give up pretty quickly. You’ll find that especially with the front end…once the car starts to push, you will need to reduce steering input immediately to bring grip back to the front end. I was doing this all day long with the car. Mind you, dropping the pressure will make them more forgiving to this. And is less of an issue on a bigger, more high speed track. I’d be curious to know how many lapping days the Z2’s get you. I’ll also report back. I took pics of my tires after the last track day. Wear is very well managed. Huge improvement over stock.
