You will get negative karma for acting shady and spinning words to suit your own conclusion. Did you do that? Let’s see…
If you’re going to quote me, actually quote me instead of posting something I wrote, and then posting a graph APR posted completely seperately.
Here’s what I ACTUALLY wrote
[quote]APR - they used the TVS1320, a rather small but VERY effective twin vortices series Eaton supercharger. Audi uses this on just about every platform above the A4 as an engine option on a 3.0 V6. This indicates a more suitable size matchup for the blower, but it still workd well on the RS4 even if it leaves a bunch of upside on the table. When it was first launched, the kit suffered…APR didn’t go to the dragstrip (or again, they didn’t tell us the results if they did) and all around it was looking like VF/PES part 3, even though the blower looked like it should work well to add 100 or so hp to the car. Turned out it was the APR tune…they had trouble taking a 4.2 FSI and tuning for supercharging. A few customers hit the strip and ran mid-high 12s…not good when the RS4 runs 12.8-12.9 STOCK. JHM’s tuner wrote a file for a friend with the APR kit that transformed the car. It went from 12.6 @ 108 to 12.0 @ 116 with just the tune change. APR asked to see the file, and started using it, in exchange for just mentioning that JHM’s tune was used on the kit. APR complied (great deal lol) but somehow managed to fuck that up with ARin and Stephen from APR denying any outside involvement. They later relented when it was clear half the forums knew the real story, and APR was losing face.
TUNE: JHM file adopted by APR
COST: $19,000, then later dropped to $15,000, then to $13,000
CLAIMED GAINS: 120 whp
ACTUAL GAINS: exactly what was claimed
So…now you look silly don’t you. I never once said that APR makes 590 hp and delivered exactly as claimed I quoted the WHP gains they posted, (430 WHP vs. 310 WHP stock) and that the gains were exactly what was claimed based on performance results we have seen. 120 whp is bang on. I have addressed this practice of using the crank hp estimates based on drivetrain loss. Those estimates are foolish to use because they assume
a) the stock car made 420 hp to begin with on the fuel you’re using…some feel that’s not possible with carbon etc. interfering
b) the car hadn’t lost any power or had any problems
c) drivetrain loss is the same on the modified car as it was on the stock car
If the stock car is making less than 420, and you ASSUME that the 420 vs. the WHP = drivetrain loss…then translate to the modified car…it’s going to make your data shitty.
So I talk WHP and don’t play crank gains.
Want more proof? Here’s something I wrote on RS246 a year ago to address those APR numbers you’re complaining about…I was addressing the difference between North America where we look at WHP whereas the Euro guys use PS or Pferdestarke or hp.
[quote]Apr uses a hub dyno and you all (in Europe) use dynos that express power in crank hp or ps
So what should Apr do? They advertised hp at the hubs on their dyno (something like 430 whp)
People (in Europe) said 'what is that at the crank (or ps)?
So Apr said’ well we don’t know drive train loss, but we can estimate it. The car we used for testing dynod 310 whp on the hub dyno when it was stock. Audi say the rs4 makes 420 ps. Therefore the car has about 26% drive train loss on that dyno. ’
Apply that to the 430whp for their tvsr1320 kit, and whammo… 590 ps.
. [b][size=12pt]Reality? Much better to let a hub dyno read hub numbers and that’s that. If someone wants to know ps, let them either dyno on a rundown dyno, or let then do an engine dyno test. However applying a drive train loss to the before numbers to get back to audi claimed power in stock form creates all sorts of problems.
I. E. What if the car before / stock had a vacuum leak? Or carbon buildup? Now you’re artificially overstating drive train loss…as the lower reading from the maintenance issue looks like extra drive train loss. And that will exacerbate the error when converting the supercharged whp to ps (on a car that is running well with no leaks, and has been carbon cleaned) .[/b][/size]
