Everything was fine on the way to work, went to leave and started in limp mode. These are the codes along with a throttle position sensor code in the transmission module. Anyone have any suggestions?
During hot days the electronic feedback can flake out for a few min. Espically if you have the car parked in the hot sun. It’s usually a passing phase.
That’s a lot of codes
The load signal generally comes from the MAF so that error says to me it’s more on the ECU side
It’s not common to see a pedal sensor error. So I would also say that might be more ECU related.
The thing that kinda sucks about the cheaper OBD tools like you have is that some of the more complicated errors you might not be able to clear. Also it’s helpful to know when the code was triggered. Like were you getting this code on key up or while driving. It does say I believe if I’m reading it right that this code has happened 4 times.
It did. I keep meaning to buy Ross tech. It lasted a while, it was a really hot humid day here. but unfortunately the air blower motor I think is going out now instead, If I remember correctly I believe I read somewhere that the motor brushes had some issues. And finally had the other brake light housing melt enough to make the led circuit board go bad ( knew that one was coming eventually).
