Hey I know h&r doesn’t list the c6 s6 as having a sway bar. Those who have the sway bar, are you just using the a6 sway bar?
I thought the A6 H&R rear set to stiffest, may fit? May be full of shit too.
I have an HnR Rear Sway bar on my car and it’s set on the stuff setting which was required to make it fit properly
Hope this helps!
Does it make a noticeable difference?
Yes it does, I also have H and R coil overs and they work well together
I also feel that the C6 lowered a bit is a very planted car and with stiffer rear sway bar it helps a lot with the nose heavy qualities with V10
Thanks. I don’t think I can do coilovers because it would be too low for track use (HPDEs) unless at stock ride height (barely clears the tires when turning hard in the corners). But since the stock springs and Bilstein HD Dampers work so well on track, it doesn’t really make sense to switch to coilovers unless it’s purely for looks or moderate street driving. Will probably give the sway bar a try though.
Right, your use makes more sense in regards to track use.
I only drive mine on smaller twisty stuff
Very fun cars to drive!
WAIT? I am confused. So S6 c6 do not have rear sway bars you say?
Hey!
Yes they come with factory sway bars, HnR are stiffer by a fair amount and offer better rear suspension performance
Cheers
Thank you. I will check em out. I was unaware of this.
