Has anyone thought of upgrading the fuel pump?
Can the fuel pump be replaced for a better/faster/more effecient one?
I wouldnt bother unless you need one because you are maxing out the stock one
If its already maxed out then better/faster/more effecient one would help?
Beem said if we were maxing it then yes change it, but we haven’t upgrade to bigger injectors and we are not pushing more than 100% power…so there is no point
Then let someone work on making better fuel rails and injectors.
#1 make the exhaust path bigger.
#2 Improve the intake system.
#3 Improve the fuel delivery system.
#4 Fix the ECU adaptation of 1,2 and 3.
= A better 3.0L.
If other car makers can get their N/A 3.0L to put out 250HP+ and a N/A 3.8L to put out 344HP stock.
What is Audi and VW doing wrong?
the ECU fixes the fuel already based on your front 02s. The 1.8T fuel pump can handle 300whp and you’re not anywhere close to that yet
youre not maxing it out N/A
[quote=“Halo549,post:5,topic:3433”]
Direct injection most likely. See the 3.2 V6, it was listed at 265hp I believe.
