Has any one had an Audi dealership do a headgasket on Audi S6 V10? If so how much and what else should i have them do why its being done?
I’ve never had it done at a dealership, but I’d say to have every gasket they can reach replaced while you can. Aging rubber can become a multi-tiered issue. Good luck.
Why do you think that the head gasket is bad? Usually the engine has to be overheated to cause the head gasket and/or head to fail.
If you see coolant in the oil then it is most likely the 4 o-rings for the coolant transfer pipes inside the rear upper timing chain covers leaking.
I’d agree with Jimmybones… as I almost always do. Head gaskets are not something that commonly go bad on the 5.2. Are you sure that’s what’s wrong
So they couldnt find anything and there is no ollen in the oil. Any ideas on where it could be coming from?
Your post didn’t make sense.
What are you asking here?
Do you mean you have coolant in the oil? If so the most common place you can see this happening is if your oil cooler. Check your O rings and oil cooler unit.
Lol did not proof read, i took my car in and they couldnt find any coolent leaking, there wasnt any coolent in the oil, and ideas hiden places it likes to leak from??
