Headers and Wrapping - How "On Point" is this article?
I posted this on AZ but figured I’ll post it here and get better TECHNICAL advice/answers. The title pretty much says all, Headers (whether JHM V1/V2 or other platform headers)…is it a bad idea to wrap them as the article reads?
Here is the article:
http://www.centuryperformance.com/exhaust-header-heat-wraps-do-not-use.html
In one paragraph, author says this:
“Cool air needs to be around the header, and insulating it with a wrap to hold exhaust heat in makes the header material surface temperatures reach near molten levels. When you wrap the header you trap the heat in the header, but also suffocate the material that needs to breathe to dissipate heat for it’s own survival.”
But in the next (directly after actually), author writes this:
“Engineers, Metallurgists, and other experts out there will state that there is no way that the material can fail because it was designed to withstand the internal temperatures of exhaust gases. This is very TRUE! But, when the header is not allowed to cool (or breathe) so as to dissipate those extreme temperatures that the wrap is controlling, you have now developed a heat absorption that compares to thermal friction. This causes temperatures to continue to rise beyond the normal exhaust gas temperatures (EGT’s) the header material was designed to withstand. This holds true as with most any type insulation.”
Thoughts from the tech gurus?
Thoughts from JHM?
Thoughts in general?
