I’ve been thinking of the best way to try and reduce the heat soak which occurs in the S6’s engine bay.
We’re sure the best way to do this is to have a more efficient and effective exhaust header system, which doesn’t PURPOSELY get really hot really quickly.
But, can we do anything on the intake side which would have a noticeable effect?
Firstly, read justincredible’s thread here: http://audirevolution.net/forum/index.php?topic=2721.0
(nice work, mate)
We can see that the spacers do have an effect - but do we know whether this is more because the manifold has been moved further from the block (reduction in radiant heat), or because the manifold has been thermally decoupled from the heads (conductive heat)?
I would tend to think it’s the latter - but we also see JHM using reflective heat tape to further drop intake temps.
I had another idea - what if the valley between the heads was insulated? The idea is to reduce the heat radiated from the block & maybe the heads too, and then also put the reflective material on the bottom of the manifold to block what’s left.
Could this potentially cause other parts of the engine (the heads, I’m thinking) to become hotter than otherwise? I’m also wondering whether it could become so hot as to damage something. There is about a 5cm gap between the manifold and the top of the block & heads.
And lastly - does anyone believe it may not even be worth the trouble? We can see a drop in temps based on Justincredible’s thread, however the manifold is specially made of a magnesium alloy which has really good thermal conductivity properties (eg. it heats up and cools down very quickly) - and he would have had to have been stationary for some short time before taking the temps (justincredible, can you confirm how long from stationary to temp reading?) Is it possible that the manifold drops down to the same running temp in both cases, after a few mins of intake air passing through it (inductive heating)?
Obviously the answer is testing, but I’m hoping we could narrow it down before I spend more time on it than I have available
Cheers!
-P
