My '04 S4 Avant 6MT won’t get better mileage than 11.5 mpg. Even with conservative driving. So clearly something is up.
I have a new air filter, fuel filter, spark plugs and pcv and still the problem continues. I’m wondering if I need to look at the MAF or front O2 sensor.
I have access to a vag-com and I’d like to troubleshoot this problem if possible. I have yet to do any data logging with it, but I have read the ross-tech how-to. Can someone with experience give me some tips on how to run some actionable logs, and then how to interpret the readings?
My guess is I’ll need to do two sets of logs per sensor. One for the maf and one for the o2. Is that correct?
I’m thinking for the MAF log: MAF, timing pull and rpm?
And for the O2 sensor: air fuel ratio, timing pull and rpm?
Car has JHM chip and piggie pipes.
Thanks
