Help - Fault Codes
Gentlemen… And Ladies
A horrible way to introduce myself, instantly asking for assistance. I was advised to post my questions on this site as I am reliably informed that the more technical hang out on here as opposed to Audizine.
So, I apologise for this introduction, but ask for help. Some of you may know me as I am on quite a few of the Audi Sites and use the same user name “JimGreen” and on Audizine I have been covering my timing chain rebuild. But now have come up with an issue now were back up and running.
I’ve just had a full timing chain/tensioner/guides/adjusters (Totally Everything, identical to JHM’s Full Plus Kit) overhaul done, but when the tech took the car for a run once he’d replaced the engine, he stated it pulls well and sounds fine, but he did notice a slight hesitation from on - off - on throttle and the engine doesn’t run as smoothly at idle as it used too. For the first 15 - 20 seconds after start up it runs really smoothly, but then runs not as smooth as normal (Not really bad, but certainly not as smooth as it should be).
So… He used VAGCOM and checked for any codes and these two came up - The car was code free prior to the rebuild :
16405 bank 2 camshaft a (intake) p0021-002 retard setpoint not reached (over advanced) mil
on and the other
16395 Bank 1 p0011-002 retard setpoint not reached over advanced mil on.
Having diagnosed exactly what the codes meant and knowing that these codes suggested the cams were over advanced and not timed correctly, he had put the car back on the ramp, locked the crank using the Audi Crank Locking Pin at TDC and checked the physical position of the cams, using the Audi Camshaft Locking Bars and everything lined up perfectly. This suggests the crank and cams have been set correctly.
He was unable to re check that the “Hall Sender Wheel” on the Camshaft Adjusters were set spot on as he was unable to get the Setting Tool between the back of the engine and the bulkhead without removing a huge amount of ancillary hoses/electrics etc etc etc, but when he built up the time gear he is certain that it was set correctly and was using the genuine Audi Tool.
He’s check the Oil Pressure which was well within specifications and a new pump had recently been fitted, Compression - Very Good on all eight cylinders, And now were at a bit of a loss as to what could be the reason for these two codes which relate to both of the Intake Cams being over advanced.
Having referenced http://wiki.ross-tech.com/wiki/index...5/P0011/000017 I see it refers to checking the following :
Possible Causes
  1. Camshaft Adjustment Valve 1 (N205) faulty - WHAT PART IS THIS AND HOW IS IT CHECKED
  2. Fuel Pump Relay (J17) faulty - NO REASON TO BELIEVE THIS IS FAULTY AS THE CAR WAS RUNNING PERFECTLY PRIOR TO THE TIMING REBUILD
  3. Mechanical Timing not correct, including Chain and/or Belt timing - CHECKED, CRANK SET AT TDC USING CRANK LOCKING PIN AND CHECKED IT HAD LOCATE CORRECTLY. CAMS CHECKED AND LINED UP WITH AUDI CAM LOCKING PLATES, AGAIN ALL LINED UP PERFECTLY.
Only item that we have not re checked to make sure it’s one hundred percent perfect (But he is certain he set it correctly during build up and used the Audi Setting Tool) is the “Hall Sender Wheel.”
Is there anything which we could have overlooked…
HELP PLEASE.
Thanks Jim
