Hey guys need help on what these fault codes mean and what i need to do to fix it.
So im driving the car everything is ruining sweet as a nut im giving it some stick after just refueling and i go to over take a car get half way past him and BOOM !!! Everything cuts out on me no power at all i did see a flash on the dash saying gearbox malfuction, i cant get past the car ive tried to over take so try and slow down to get back on the right side of the road but i can not as the guy i tried to over take blocks me untill i come to a stop, so not good as now im on the wrong side of the road waiting for a head on !! Car won’t start at all then a car comes head on over the hill luckly his not going fast so manages to stop ! THANK F*#K for that. I try to start the car again and it starts
So i drove home and car run great no problems ?? conected the VCDS and this is what i found.
Thursday,30,April,2020,16:24:36:52040
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 84150km-52288mi Repair Order:
Gateway Installation List: 8R0 907 468 N
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
04-Steering Angle – Status: OK 0000
08-Auto HVAC – Status: Malfunction 0010
09-Cent. Elect. – Status: Malfunction 0010
14-Susp. Elect. – Status: OK 0000
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1B-Active Steering – Status: OK 0000
22-AWD – Status: OK 0000
30-Special Function II – Status: OK 0000
44-Steering Assist – Status: Malfunction 0010
53-Parking Brake – Status: Malfunction 0010
56-Radio – Status: Malfunction 0010
5F-Information Electr. – Status: Malfunction 0010
6D-Trunk Elect. – Status: OK 0000
Address 02: Auto Trans Labels: 0B5-927-156.clb
Control Module Part Number: 8T0 927 156 J HW: 0B5 927 156 K
Component and/or Version: 0B5 42 FSIRdW H02 0004
Software Coding: 000001
Work Shop Code: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015 (AU48)
ROD: EV_TCMDL501021.rod
VCID: 44D14B1CFE176BAB37A-8010
6 Faults Found:
7969 - Signal Line for Tiptronic
P1890 00 [036] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 84145 km
Date: 2020.04.30
Time: 15:23:52
Engine speed: 0 /min
Transmission input speed: 0 /min
Transmission output speed: 19 /min
Engine torque: -44 Nm
Transmission fluid temperature: 73 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Unlearning counter according OBD: 40
Voltage terminal 30: 12.500 V
W006_Vwh_PrzWh_Whs1-Data: 49.85 %
W007_Vwh_PrzWh_Whs2-Data: 49.70 %
Selector lever maximum pulse width High-Data: 4.006 ms
Selector lever minimum pulse width High-Data: 3.996 ms
Selector lever maximum pulse width Low-Data: 34.777 ms
Selector lever minimum pulse width Low-Data: 34.686 ms
9723 - Shift Lock Solenoid (N110)
P1761 00 [036] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 84145 km
Date: 2020.04.30
Time: 15:23:55
Transmission output speed: 38 /min
Status of selector lever lock: not active
W001_Vwh_WHPosFS-Data: N
Transfer speed from ESP: 4.78 km/h
8007 - No Communications with Steering Angle Sender (G85)
U0126 00 [036] - -
[Lost Communication With Steering Wheel Angle Sensor Control Module]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 84145 km
Date: 2020.04.30
Time: 15:23:52
Transmission output speed: 16 /min
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.899 V
8015 - Steering Column Control Module
U0212 00 [036] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 84145 km
Date: 2020.04.30
Time: 15:23:52
18053 - Shift Fork 3
P284B 00 [096] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 84144 km
Date: 2020.04.30
Time: 15:23:18
Engine speed: 4407 /min
Transmission input speed: 4407 /min
Transmission output speed: 644 /min
Engine torque: 536 Nm
Transmission fluid temperature: 70 °C
Accelerator position: 100.0 %
Clutch status: Kupplung 2 kann Moment ĂĽbertragen
8463 - Supply Voltage: Terminal 15
P1758 00 [036] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 84145 km
Date: 2020.04.30
Time: 15:23:53
Transmission output speed: 21 /min
Voltage terminal 30: 12.400 V
Terminal 15 status: Terminal 15 off
Address 01: Engine Labels: 079-907-560-CFS.clb
Control Module Part Number: 8T2 907 560 E HW: 8T1 907 560
Component and/or Version: 4.2l JHM93 / H04 0003
Software Coding: 1225003225A6000A2000
Work Shop Code: WSC 06341 128 28888
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002 (AU48)
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E2539F490FB017B61E-806A
2 Faults Found:
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [032] - -
[Transmission control moduleRead out DTC]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 84144 km
Date: 2020.04.30
Time: 15:23:18
Engine speed: 5592.50 /min
Normed load value: 34.9 %
Vehicle speed: 79 km/h
Coolant temperature: 98 °C
Intake air temperature: 23 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.711 V
Engine status-Bits 0-7: 3
Engine oil temperature: 110.3 °C
Engine operating condition: full load
Engine operating condition-Test_Program_Channel 87: 7
7781 - Engine Off Timer Performance
P150A 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 84145 km
Date: 2020.04.30
Time: 15:24:28
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.250 V
Fuel pump: specified value: 10.001 %
Low fuel pressure: specified value: 700.0 kPa
Fuel temperature: 93.0 °C
Adaptation of Fuel Pump (FP): -139.9 kPa
High fuel pressure: specified value: 4.9920 MPa
Readiness: 0000 0000
2 Faults Found:
U1026 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 84144 km
Date: 2020.04.30
Time: 15:23:18
P150A 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 84145 km
Date: 2020.04.30
Time: 15:24:28
Had a mission getting these logs on here am rubbish with this sort of stuff lol so sorry if its not how it should be ! Thank in advance guys took car out last night again after clearing DTC’s and pushed it a bit and was perfect no issues ?? But i still want to know what the cause was and if i can resolve the issue as my trust in the car is not there after that !!
