So I’m pretty much done with my manual transmission swap on my 2005 Audi S4. I can’t seem to find a swap guy that is actually for my car. Everything I seem to find it for the B5 S4 or something else.
Ok so here at the 3 swap guides I have been following:
https://s4wiki.com/wiki/Tip_To_6spd_Conversion
https://www.audiforum.ca/a6-s6-rs6-71/tiptronic-6-speed-manual-transmission-swap-diy-59468/
http://www.audizine.com/forum/showthread.php/460049-TipTronic-to-Manual-Transmission-Swap
I took the small relay out from under the ecu and made a jumper wire as shown by drjonez.
I ran a wire to ECU pin 39 and splice bed in for the clutch pedal switch. What I’m not quite sure of is the reverse light switch on the manual transmission. I read somewhere that says that needs to be connected to pin number 7 and 8 on the Tiptronic multifunction switch wiring harness. Does anybody have a definitive answer on this?
Cross post on audizine…
http://www.audizine.com/forum/showthread.php?t=780209
Calling all TIP to 6 speed manual swappers
