Help resetting nav unit
i raised this issue in another thread, but I’ll start a new one here.
I confirmed with the dealer that 4E0060884EG is the correct update DVD for my 2G MMI. Got one on eBay. Intially when I put it in it wasn’t recognized. I determined that to do the update you need to put the disc in and then key up (https://www.youtube.com/watch?v=kcaSmElTThY). The update seemed to start fine, and then got hung up at 6%. As I was sitting there I got a call that went to blue tooth. After the 5 minute call, I turned the car off.
Now the lights on the nav unit flash red, the MMI says “navigation not installed”. When I go into VAGCOM says “controller not found” in the 37-navigation selection.
