tell them to do a tune!
I think if that was on AZ it might get a bit more discussion?
Wonder when the problem presented itself and how long he drove like that for…
These codes are the result of a plausibility check that tests (under certain enable contions) if the post cat O2 sensors see a (very) lean condition when the engine is in pull with cylinder shut off. Depending on the position of the sensors in the aftermarket header this can falsely be triggered.
To ged rid of it the calibration has to be changed accordingly.
Disabling certain diagnosis is not the best idea with rate based monitoring.
Anyway this should have no effect on driving.
have yet to test via vagcom. Once the spacers are removed I’ll give it a shot.
Thanks for your input Silentbob!
I was hoping the codes were the cause of the minor performance issues I’ve been having but based on your post it doesn’t seem to be the case. In any event, I’ve scheduled to have the spacers removed and will see how she drives after that.
what performance problems are you having?
running 12.2-12.3 @ 113+ = no problem
Well when you put it that way…
Seriously, I want to get back to the strip and see if this is all in my head!
it usually is. Kinda like carbon. People stress carbon buildup far too much…but when you do the performance testing, it’s not really THAT bad.
Or just log your car in 3rd gear from 2000-7000 Rpm going WOT…and do so every few months. Then you have a ‘standard’ to compare to…to measure how quickly you’re going through the RPMs. Choose a flat road, use the same one every time. Once you think your car is lagging a bit, re-test it. Note conditions (DA) etc.
Well the good news is that I seem to have fixed the problem! ;D
The bad news is I’m pretty sure I was running the 100 tune for about a month on 94 octane! >:(
Still not sure how it could have happened, I did let a friend drive the car to and from the drag strip but I didn’t think program switch was possible while moving? Oh well, can do anything about it now.
Now get 100 gas in there and run again…
Yikes…good thing your tuner doesn’t disable knock sensors!
Also good thing you live in the land of 94…not Californian 91 piss
I agree on both counts! Still not 100% sure of what happened though
Hey bear, just read this. Crazy!
I dunno, I didn’t feel anything strange when I took it down the strip…
I have watched VCDS once running 100 tune on 94, I watched timing retard 10 degrees on all cylinders from what seemed to be medium highway throttle application. I pulled over and switched it back…I wanted to know how close we were to using methanol injection with 94 gas on 100 tune. It was further than I thought.
But I’d imagine the computer would shut things down at some point…that’s how you got the CEL, then? Misfires?
can you explain this further because it sounds interesting and I’m confused. The ECU pulled 10 degrees of timing using our 94 on the 100 file…but how do you know what running 94+meth would have done? (i.e. how do you know how far 94+meth on the 100 file is from 100 on the 100 file?)
Also have any of you guys sent logs to APR on 94 using their 93 file? I bet there’s more in it. Our 94 is great for power and the cars love it. I bet they could write a slightly more interesting file for PetroCanada 94 guys. JHM used to always comment about how amazing my logs looked when I’d send them to them.
Also have you logged your car on 100 to see retardation in various conditions (good DA, shit DA etc.)?
Also where’s my memory card?
J,
Not sure when, or if for that matter, the map was changed from 93 to 100 but if it was in fact change it was most probably changed on the ride back from the strip. I let a friend drive the car back and I remember him playing with the cruise control stack but didn’t think you could change programs while the engine was running so I wasn’t concerned.
Good point saki, I was assuming I could make up for a few degrees of timing advance, but that was a total guess. Still, the amount of timing retard pull under even medium load blew me away.
On the other hand, it seems Bear did an awesome R&D experiment, and came out alive. We need to know how much you drove and if possible, how many time you went WOT. Im surprised as heck your car is ok!
I’ll likely be going to Cayuga tomorrow, to the strip. Company always welcome…!
My post got cut…
On the other hand, Bear did the ultimate experiment and came out alive. We need to use this info! Bear, how much did you drive like this, and if you remember, how much WOT?
I’m going to Cayuga tomorrow, the strip, company always appreciated…
EDIT: my post only shows cut on Tapatalk…? wtf.
hahahaha that’s a really scary R&D experiment…especially on an out of warranty car.
any answers?
Lol…save me a trip and come to Cayuga…
Or email me if tonight is ok, I’ll drop it off
sure thing
what about the other questions? I’d like to see what we’re getting out of our fuel here. I get the feeling it’s pretty frigging awesome. I’d like to see if there’s any timing pulled on the 93 file using 94 octane petro canada on your cars in decent/good/shit conditions. I bet there’s virtually none until it gets hot.
[b]1. Also have any of you guys sent logs to APR on 94 using their 93 file? I bet there’s more in it. Our 94 is great for power and the cars love it. I bet they could write a slightly more interesting file for PetroCanada 94 guys. JHM used to always comment about how amazing my logs looked when I’d send them to them.
- Also have you logged your car on 100 to see retardation in various conditions (good DA, shit DA etc.)?[/b]
I definitely agree with your octane assumption, especially for the F/I cars. But I’m also thinking it makes a larger difference on our N/A (B7 RS4) than most realise or assume.
