I might just install the Supersprint Racing headers for the S5 3.0T while the car is in service mode and being serviced to much… So much to do…
The headers will be ceramic coated, the original heat shields do not fit anymore.
But now the question: High-Flow Cats, I find myself doubting between 100cpsi or 200cpsi.
100cpsi Tri-Metal
- have a better flow (should), but I also read that for the 100cpsi core to hold up, they use bars to keep the core from collapsing under pressure. Which can lead to less flow.
- APK/ TUV Check can cause problems with c02.
- Read about degrading faster after 15k and smell goes up and CEL comes up.
200cpsi Tri-Metal
- Nice flow
- Most of them pass through the gas tests
- No degradings found
How much of the issues with the 100cpsi cats are true for those of you who have installed and use them?
