I haven’t touched the front brakes. They look like they have a lot of pad material left.
When I replaced the rear rotors and pads I did the bed the brakes process.
They squeaked once and a while.
After about 15-20k miles they squeaked almost all the time when stopping.
I don’t stomp the brakes when stopping. If I do no squeaks.
But if I use them to slow down early and only have to barely bush them to stop the squeaking starts.
So I decide to change the pads because the shop I go to said they look like they needed replacing.
Did the bed the pad process.
After a day the squeaking started. Same as before.
Right now its old rotors and new pads.
I think I gave the pads room to move around because I cleaned the pad cradle pretty good.
The original pads when I replaced everything had to be tapped to brake them loose from the caliper cradle.
