So removed the 2 nuts on the top, but it is not budging, I had a look under the wheel well but couldn’t see any fasteners from underneath.
What am I missing?
What am I missing?
From what I can see in the etka picture it looks like its an interference fit.
Why are you trying to remove the coolant tank…
It’s the coolant expansion tank, need to move it so I can get to the bolts that hold the front strut mount in
That makes sense. From what I can see the coolant tank is just a press fit other than the two nuts. Maybe check the black box connections to the body.
Thanks. I levered it up with a pry bar to get enough room to undo the suspension bolt
