How-To: C6 S6 Intake Manifold Removal & Carbon Clean
Hi all,
Trying to get this down while it is still fresh, so this will be a work-in-progress.
First - here are the tools you will need:
  • 3/8 or 1/2" drive ratcheting wrench
  • 1/4" drive ratcheting wrench
  • 1/4" Drive Torx T30 (picture later)
  • Long bit Torx T30 (I used 1/4" drive - picture later)
  • Short (normal) bit Torx T30 (I used 3/8" drive)
  • M8 Triple Square/12 Point
  • M10 Triple Square/12 Point
  • 10mm Wrench/Spanner (stubby is better)
  • 14mm Wrench/Spanner
  • 17mm Wrench/Spanner
  • Needle Nose Pliers
  • Flat Screwdriver
  • Precision (tiny) flat screw driver (for clips)
  • Extendable magnet
Before you start - repeat the following 10 times: “I will not drop any screws.” I haven’t (yet), but it’s not like an old Nissan - every screw is important!
Another thing to note is that a lot of these screws are aluminium, so be sure your bit is well seated, that there’s no debris in the screw head, and use lubricant before excessive force. If you do strip one, you can hammer the next size Torx into the hole and the material is soft enough to allow a new imprint to be made.
Give yourself about 2 hours.
Step 1 - Take off engine covers. One at the front, one at the back. Remove intake pipes between manifold and air filters. (NOT PICTURED)
Step 2 - Unclip the wiring harness on the left side. Unclip the two clips circled in red. You don’t need to remove the ground wire circled in green. The two arrows point to clips attached to the fuel lines. Gently pull these off. Lift the wiring harness over the fuel pump to the left side and leave there.
http://i57.tinypic.com/33ber9k.jpg
Step 3 - Do the same on the other side. There are no fuel line clips on the right side.
Step 4 - Remove the PCV vent hose from the left hand side (squeeze and pull). You need to remove it from the valve cover and from the oil separator. Move the hose out of the way. You can leave the right side connected. Put a rag or something to block debris from going into the opening in the valve cover.
http://i62.tinypic.com/16i9qgh.jpg
Step 5 - Remove the valve/hose. Squeeze the clamp with the pliers and pull the hose up.
http://i59.tinypic.com/2hxa7gj.jpg
Step 6 - Remove the ‘air distribution housing.’ There are 8 Torx T30 bolts holding it to the manifold. You will also need to remove the bracket connecting the oil separator to the right hand side throttle body. Remove the two M8 12-pt bolts on the throttle body and the Torx T30 on the oil separator.The housing should now lift away. It may be a good idea to replace the bolts onto the throttle body so you don’t lose them.
http://i57.tinypic.com/2cej0hf.jpg
Step 7 - Remove the oil separator. There’s very little clearance between the firewall and the oil separator, so this is where you will need your 1/4" ratchet and 1/4" drive Torx T30. Remove the bolts (be careful not to drop the bottom one), and pull/push the oil separator towards the firewall to remove it.
http://i58.tinypic.com/2nl5kb6.jpg
Step 8 - Fuel lines. The factory service manual says to remove the fuel lines and the fuel pumps, but I found this wasn’t necessary. Nonetheless, you must remove one line and loosen the others in order to free the manifold. We’ll do this step now so you can let the fuel drain out while you do the rest. I was expecting these lines to be under high pressure, but they weren’t. Put a rag around the connection as you loosen it in order to soak the fuel. When you do the rear connection, be aware that more fuel will come from here than from the pump connection.
http://i62.tinypic.com/efi8t2.jpg
http://i60.tinypic.com/2v1p4t0.jpg
Now loosen the two lines on the left hand side, at the pump only.
Step 9- Now move to the front of the intake manifold. Remove this little hose and move out of the way.
http://i59.tinypic.com/24zeu68.jpg
Step 10- Remove the little module at the front left of the manifold. I don’t know what this thing is, and can’t find it in ETKA - some sort of vac sensor - someone will educate me! Unplug the connector, the two hoses, and then remove the bracket it is attached to. One 10mm bolt and one Torx T30 hidden underneath. To remove the 10mm nut, use the stubby wrench, rather than a socket. Using a socket will cause you to foul the hose barb sticking off towards the right, and you don’t want to break it.
10b - remove the engine lifting bracket. Otherwise this will foul the manifold when you try to remove. 2x Triple square/12pt M10.
http://i60.tinypic.com/2lvl6y8.jpg
Step 10 - Remove the wiring harness plugs from the three actuator motors, and two actuator position sensors. I had the advantage of having already removed the radiator, so this was easy when you looked from underneath. This may require small hands to complete without the radiator out.
Step 11 - Time to remove the manifold. Up until now you could remove all the Torx with the shorter type, but you won’t be able to get to all the manifold bolts with it. You need a longer type - I used a Blue Point BLPTL1430:
http://buy1.snapon.com/catalog/objects_lg/images/BLPTL1430.jpg
It’s a 1/4" drive, but I just adapted to 3/8"
You will need to move the fuel lines around slightly to get clear access to the manifold bolts. There are 12 of them.
Loosen all the bolts and remove them with your extendable magnet. It will be hard to get to some with your fingers, and you may need a friend to wiggle the manifold and fuel lines to help you free a couple of them. Be careful when removing the rear screws - DO NOT DROP THEM. The rear left one has the highest danger of dropping into never-never land.
Slide the manifold forward slightly, taking care not to damage the gaskets if you plan to re-use them. Lift from the right side and it should come out.
YOU’RE DONE. If you’re lucky like me, you may find some little plastic gifts left for you in the intake runners!
http://i59.tinypic.com/2wh4dy0.jpg
Part 2 will include the carbon cleaning, once I’ve done it!
-P
