well said - pretty comprehensive.
Seems like 90% of the problems on the V10 cars is in the top end; carbon, injectors, coils plugs, all affected by the PCV operation. If any of these gets neglected problems snowball downstream into catastrophic failures.
A bad PVC will lead to more carbon buildup. Carbon buildup could take out an injector. a bad injector will eventually cause a cat and/or O2 to fail. The first few items are what a majority are trying to address and cause misfires, rough starts, rough running. Rough running puts a lot of stress on the motor mounts as well causing them to prematurely fail.
Price out the labor to drop the engine to replace a cat or O2 and tell me that installing the correct parts the first time isn’t worth it. Price out the cost of the engine mounts and tell me it’s not worth it.
I’ve tried replacing just the injectors on the misfiring cylinders - while the misfires went away, it wasn’t the miracle cure I’d hoped for. Reading several different measures outputs on these particular injectors, the flow rates are in fact all over the place - seems like the best you could hope for is a 20% variance across a set of new injectors. Who know about rebuilt ones… Genuine Audi injectors are about $150/ea. Generic Hitachi 06E906036AC’s that may or may not have VAG markings are about $10 cheaper.
so worst case scenario, you’re spending $900 for a documented flowmatched set vs. $1300 for a set that varies by 20% or more? How’s that not amazing. Send in your ratty take off injectors that you just replaced and you get $300 back?!
I’ve spent at least $900 already trying to sort the injectors.
My bad. If Id’ve know 2weeks earlier blah blah blah… I’m DEFINATELY going to do this, but since my halfass mix-n-match seems to have fixed my misfires for now, I’m going to wait till I replace the intake hoping I’ll stay good until then…
IMO if you’re still running injectors from the factory and you’re at a point that you’re doing a carbon clean, it’s a folly not to pony up the $900/$600.
Don’t be like me and double or even triple buy the same parts when you don’t need to. Some corners you can cut, but this isn’t one of them.
I’d offer to sell the 12 various condition injectors I’ve got so you can have a go at the rebuild at a heavy discount, but I need em for the core charge
