Hi everyone-
I haven’t frequented these forums in awhile, but I bought my second s6 an 07 with 78k miles (98k miles now) a little over two or so years ago. Some of you all may recall the JHM promo video for breaking into the 12s. My car was the white one, it was at JHM for a lengthy stay, I actually had it shipped directly to JHM when I bought it to be part of the beta program. The car ran flawless for a little over a year (thanks jhm and count!) but the last few months have been tough.
I’ve had coldstart misfires and just misfires in general for the better part of the last 4-6 months.
So far I’ve performed the following:
- another carbon clean and pcv replaced
- replaced all the injectors (second set in <2 years)
- Swapped plugs and coils to rule that out.(coils and plugs were replaced during JHm visit about 2 years ago now)
- Checked compression and it was fine.
- Replaced the Intake manifold (thanks jhm for the latest one!)
- Replaced throttle body gasket
Tomorrow I am having them test the battery, clean the MAF, clean the airfilters, and replace the fuel filter. The low side fuel presssure was closer to 6 so thinking the fuel filter may be a bit clogged can’t recall when it was last done. Crossing fingers, but not entirely sold that will fix the issue. I’ve also read that the misfires could be caused by loose coil clips, when cold it creates a lean scenario and causes misfires. Once warmed up there is expansion and then no more misfires.
If that doesn’t fix it and after searching a few other threads I’m starting to think it could also be a bad 02 (I believe one was replaced by JHM already), possibly even bad cats, and/or the SAI. One thing of note I haven’t gotten better than 15 mpg since I got the car back from jhm but before I took it back to the shop it was hovering around 11 or 12, so thinking it is fuel related, but I guess it could be a bad O2 as well. Whatever it is it has to do with the startup routine, when I was still driving it, to get it to misfire less I had to turn it on then off then back on to get it a little smoother and out of the startup routine. The car has misfired so badly before that it has stalled out, this is after a few minutes of driving but not fully warmed up.
To be updated after I land…if the above doesn’t fix it I’ll have codes on Friday or so. It’s basically cold start misfiring on 5, 6, 7 and 8 from what I recall. Before the IM was replaced it was a hard misfire on cylinder 8 I believe. There is also a esp cel on for the yaw sensor, I’m told this is a different issue and not related but I suppose there could be a correlation of my issue is electrical.
Look fwd to resolving this soon with everyone’s help. Especially since my Audi vw mechanic is starting to scratch his head :-\ sorry for some of the rambling above I’m typing this before I take off in a plane.
About the car
2007
Audi ibis White s6
98000 miles (cpo to 60,000 miles and no records between 60 and ~78k miles when I bought it)
Mods:
JHM ECU/TCU
JHM LW CP
K&N air filters
Magnaflow mufflers (I believe)
JHM front LW rotors (currently not installed, maybe for sale if anyone is interested)
Major Maint and repairs in last 20k miles:
10 flow matched injectors
New spark plugs and coilpacks
New intake manifold
Meyle XD Control arm kit
Front and rear Bilstein HD struts
Coolant expansion tank
Inner outer CV Boots
valve cover gaskets
Oil cooler O-rings
Resealed oil pan seal
Crank seal
New Radiator
Carbon clean (twice)
Cabin air filter
O2 primary Sensor B1
New battery (I’m in Arizona and heat isn’t friendly to these batteries, I also realized I never had the battery coded to the car so not sure if that might be causing an issue as well)
I think that’s the majority of it, I’m sure I’m missing a thing or two.
