I'm considering a pro-m maf for my build.
Here is the maf I’m considering for my build.
http://promracing.com/mass-air-meters/pro-m-slot-style-mass-air-sensor.html
I will finish the car and run a stock hitatchi sensor in the 85mm housing I have now. I’m very interested to see if i can refine the car even more with a sensor that is supposed to have a much better resolution… I know some of you on here are looking at the same thing, so I figured we can have a spot to report back on the pro-m maf.
You get a 30 point cal sheet for your tuna and can specify for which housing size you would like it calibrated.
That would be an excellent choice Josh. I am excited to see how my slot style blow through works out on my project car, if it does I will most likely change out the lightning maf on my S4 to an 85mm pro-m
EYEspI, are you Mantis on AZ? And Josh, aren’t you tuning Mantis’ single turbo A6 with this sensor in blow-through config?
Anywho, I can’t comment on that maf in particular, but I’m running a slot-style MAF sensor (PMAS HPX) in pull-through conig, and I have no issues at idle.
I am tuning the mantis car with that maf setup to blowthrough.
I want to run mine draw through.
I’m gonna do this to see if it’s worth doing on something other than a 700+hp car.
Pro-m is an excellent choice.
Yup
Werd.
I have a pro-m that is for sale… new in the package w/ pigtail… PM me if you’re interested I suppose…
Eventually I will put up a FS thread for everything that I will be selling.
