IM Flap Position Sensor-Electrical Malfunction/Camshaft B/Crash ensors
Hey guys!
It’s been a while since I’ve posted. Car had been running pretty well for a while after cleaning some injectors. I’ve got a few problems that need addressed for state inspection namely:
008212 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 - 002 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 213752 km
Time Indication: 0
Date: 2007.04.18
Time: 11:04:26
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 63.0°C
                Temperature: 43.0°C
                Absolute Pres.: 1000.0 mbar
                Voltage: 13.589 V
The electrical malfunction has me thrown off. It’s not coding as stuck or closed/open. Could this be a bad connector under the IM? Immediate CEL after clearing codes on startup.
Next:
000036 - Bank 2: Camshaft B (Exhaust)
P0024 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 213752 km
Time Indication: 0
Date: 2007.04.18
Time: 11:08:15
         Freeze Frame:
                RPM: 1152 /min
                Load: 21.6 %
                Speed: 15.0 km/h
                Temperature: 68.0°C
                Temperature: 38.0°C
                Voltage: 14.224 V
I’ve never experienced this code before. Another forum search result showed possible clogged oil screen on the camshaft adjuster? Just cleared this code so we’ll see when it returns.
Lastly:
1738 - Crash Sensor for Front Airbag; Drivers Side (G283)
014 - Defective - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Anyone experienced these going “defective”? Replacement needed or possibly wiring?
The help is greatly appreciated!
