I did measure the temps. It was a drastic drop. I had my car with spacers and another car without spacers. So we had real time comparison.
I don’t remember the exact temps but the smallest I saw was 40deg F and the most I saw was almost 89deg. They seriously work.
We have logs from before and after. So you don’t just see the intake temps looking better but you can measure the knock voltages and see there really is an impact.
The 8mm is big enough to achieve the needed results. Bigger isn’t going to most likely yield more. When you take into effect the fact that the hard fuel lines only have so much play in them. So that comes into play.
The other things we see is how the cooler air charge helps reduce the carbon impact. The fact that the cooler temps cut down on the mist also help performance. Cutting down on the under hood temps also helps other components like hoses and other supporting plastic parts.
We have a good pool of results from The 5.2 to all of the 4.2 cars and then the domestic guys that run something similar.
As for the DIY. The material is toxic. sorcing that stuff then cutting it and trying to get it to fit would just be a big nightmare. For the cost the DIY would not be IMO a smart way to go. The spacers have a special taper to them.
My opinion. They are one of the top mods for the overly hot 5.2.
