In serious need of technical expertise
Good news is that I finally remedied my O2 sensor faults after replacing all of them with new ones. However, I now having some serious other issues. My car battery finally died while I was on leave for two weeks. We first tried to jump it which lead to real bad misfiring and stalling conditions. Had the battery checked, and it cam up 6 volts. Replaced it, and have come to the conclusion that it was probably still the original. Started car, and it basically ran like shit. Ran VAGCOM and it detected multiple misfire on cylinder 5. Decided to replaced the spark plugs since I am betting they are p’bly original, too. Car still had issues under acceleration. Ran VAGCOM again, and the multiple misfire had moved from cylinder 5 to cylinder 8. This led me to decide to swap the coils. Guess what? Still having issues under acceleration. Ran VAGCOM again and now the misfire is on cylinder 4. I have checked the fuses in the door and near the ECU under the hood and they look fine. Also, each time has thrown the CEL, of course, going from flashing to solid. I also now have some other low voltage codes around the interior of the car. I will post the readouts from VAGCOM in order from oldest to newest. Also, only faults that occur, not all addresses.
AFTER BATTERY REPLACEMNET BUT BEFORE O2 REPLACEMENT_______
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: STG1 SC/V4 JHM ª0060
Revision: 57H13— Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 05136 444 53285
VCID: 2447AFD4E7CD8D012A7-8071
4 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: -40.0°C
                Absolute Pres.: 0.0 mbar
                Voltage: 0.000 V
012902 - Oxygen (Lambda) Sensor B1 S1
P3266 - 008 - Internal Resistance Implausible - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124694 km
Time Indication: 0
         Freeze Frame:
                RPM: 775 /min
                Load: 29.4 %
                Speed: 0.0 km/h
                Temperature: 34.0°C
                Temperature: 30.0°C
                Absolute Pres.: 810.0 mbar
                Voltage: 13.589 V
000304 - Oxygen (Lambda) Sensor B1 S1
P0130 - 001 - Malfunction in Circuit - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124694 km
Time Indication: 0
         Freeze Frame:
                RPM: 778 /min
                Load: 30.2 %
                Speed: 0.0 km/h
                Temperature: 37.0°C
                Temperature: 30.0°C
                Voltage: 13.589 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124705 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 102.0°C
                Temperature: 50.0°C
                Voltage: 12.319 V
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5544E88A134279EBD-807E
1 Fault Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 37
Time Indication: 0
         Freeze Frame:
                Hex Value: 0x0000
                Hex Value: 0x4222
                Hex Value: 0x0024
                Hex Value: 0x0194
                Hex Value: 0x0001
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Voltage: 0.000 V
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124694 km
Time Indication: 0
         Freeze Frame:
                RPM: 877 /min
                Load: 42.3 %
                Speed: 7.0 km/h
                Temperature: 43.0°C
                Temperature: 32.0°C
                Voltage: 13.843 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124694 km
Time Indication: 0
         Freeze Frame:
                RPM: 877 /min
                Load: 42.3 %
                Speed: 7.0 km/h
                Temperature: 43.0°C
                Temperature: 32.0°C
                Voltage: 13.843 V
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71E996803BBF68A9911-4AE8
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11880
Shop #: WSC 06335
VCID: 78FFABA458C539E156F-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
9 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver’s Side
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
2ND VAGCOM RUN AFTER REPLACING SPARK PLUGS__________________
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124726 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 87.0°C
                Temperature: 58.0°C
                Absolute Pres.: 800.0 mbar
                Voltage: 12.319 V
Readiness: 0010 0100
3 Faults Found:
004982 - Cylinder 8 Ignition Circuit
P1376 - 004 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124726 km
Time Indication: 0
         Freeze Frame:
                RPM: 1218 /min
                Load: 49.0 %
                Speed: 0.0 km/h
                Temperature: 75.0°C
                Temperature: 51.0°C
                Voltage: 11.684 V
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124726 km
Time Indication: 0
         Freeze Frame:
                RPM: 792 /min
                Load: 32.1 %
                Speed: 0.0 km/h
                Temperature: 75.0°C
                Temperature: 54.0°C
                Voltage: 13.589 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124726 km
Time Indication: 0
         Freeze Frame:
                RPM: 792 /min
                Load: 32.1 %
                Speed: 0.0 km/h
                Temperature: 75.0°C
                Temperature: 54.0°C
                Voltage: 13.589 V
Coding: 11880
Shop #: WSC 06335
10 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
MOST RECENT AFTER COIL CHANGE_
1 Fault Found:
004964 - Cylinder 4 Ignition Circuit
P1364 - 004 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124760 km
Time Indication: 0
         Freeze Frame:
                RPM: 773 /min
                Load: 25.9 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 46.0°C
                Voltage: 13.589 V
Readiness: 0110 0100
Coding: 11880
Shop #: WSC 06335
10 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
