I finished my carbon cleaning and injector cleaning.
For the injector filter baskets, there is not any flow difference between the oem plastic filters and the stainless ones. I went ahead and used the stainless filters. My injector basket filters were all extremely clogged or broken. The flow rate on the injectors was horrible and varied. After running them through the injector cleaner several times they all have the same flow within about 2%.
My intake valves had a lot of carbon build up. It had significantly more carbon than my A6 had when I clean its valves. Also I had broken intake flap parts as well. It looks like I will be sourcing a new intake manifold soon.
After the injector cleaning and carbon cleaning, this car performs so much more. It’s definitely a huge difference.
