Intake Manifold Bolt Size
Anyone know what the intake manifold bolt size is?
The reason I am asking is I may try again to install the JHM intake spacers I have. When I first installed them, I had a vacuum leak that I never could get sealed. Thinking about it recently, I am starting to suspect that it was a problem with the JHM provided stainless steel bolts. When I tried to do a re-torque of the bolts to try to re-seal the manifold, I had two of them strip the hex head and they were a bitch to remove. I am thinking I will get a set of ARP chrome-moly bolts if I can get them in the proper size and length.
Thanks.
