In the process of troubleshooting an issue with my engine, I may remove the top half of the D2 S8 intake manifold to ensure that the variable intake runner flaps are not damaged. There is a gasket that runs around the port openings on the bottom half of the manifold. You can see it outlining the port openings in the pic below
http://i37.photobucket.com/albums/e90/russiandenis/S8%20intake%20vs%20regular/PhotoAug3024216PM.jpg
Does this gasket need to be changed when I put things back together, or is it reusable?
