As I have said multiple times there is only one way to make any pertinent measurememts. I have a b.s. BIS I switched from engineering physics. I was a physics major before that.
If you have the change in temperatures and an unknown and area also as an unknown your heat flux will equal be equal to your delta t over q which is a unit of area with out knowing one or the other your numbers prove nothing.
[quote=“JCviggen,post:59,topic:7232”]
aluminium? your manifold is made of aluminium? that must be a one off
Sorry the actual equation would have to be dQ*h= dA/deltaT where dQ is the thermal power given off by the engine, h is the transfer coefficient or how conductive the materials transfering the energy are dA is is the area of direct contact. If you don’t know either dA or delta you cannot have any conclusive results no matter how accurate your heat measurements are which for the record will be not very.
