Intermittent P0021 - Timing issue?
07 S4: 98k miles
In the last couple weeks I’ve had my CEL come on a couple times. I normally don’t DD this car in the winter but my A4 got plowed in at the back of my driveway and the mound of snow is now solid ice… oops. Anyway, I first noticed the issue when it was 6 degrees F out on a cold start. Had a flashing CEL right after start up at idle for a few blinks then it was out. Car drove normal. The following day after the car warmed up I gave it some gas and it barely accelerated. I pulled over, shut it down and restarted it and the CEL was on. I brought it over to my shop scanned it and here’s what I got.
Thursday,05,February,2015,08:34:46:42923
4 Faults Found:
004392 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157562 km
Time Indication: 0
         Freeze Frame:
                RPM: 1872 /min
                Load: 12.5 %
                Speed: 60.0 km/h
                Temperature: 75.0*C
                Temperature: 1.0*C
                Absolute Pres.: 1010.0 mbar
                Voltage: 13.716 V
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157673 km
Time Indication: 0
         Freeze Frame:
                RPM: 912 /min
                Load: 14.1 %
                Speed: 0.0 km/h
                Temperature: 28.0*C
                Temperature: 21.0*C
                Voltage: 13.462 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157673 km
Time Indication: 0
         Freeze Frame:
                RPM: 1348 /min
                Load: 12.9 %
                Speed: 0.0 km/h
                Temperature: 32.0*C
                Temperature: 20.0*C
                Voltage: 13.462 V
000033 - Bank 2: Camshaft A (Intake)
P0021 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157673 km
Time Indication: 0
         Freeze Frame:
                RPM: 1047 /min
                Load: 11.0 %
                Speed: 0.0 km/h
                Temperature: 29.0*C
                Temperature: 21.0*C
                Voltage: 13.335 V
Shit, a timing code w/ misfires… Cleared the codes. Started the car back up and rescanned. No codes. Drove the car for a week with no problems then the light came back on. Rescanned:
Friday,13,February,2015,22:26:19:42923
2 Faults Found:
P0021 - 004 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158097 km
Time Indication: 0
         Freeze Frame:
                RPM: 767 /min
                Load: 12.2 %
                Speed: 0.0 km/h
                Temperature: 58.0*C
                Temperature: 33.0*C
                Voltage: 13.589 V
P1128 - 001 - System too Lean - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158482 km
Time Indication: 0
         Freeze Frame:
                RPM: 1987 /min
                Load: 9.8 %
                Speed: 51.0 km/h
                Temperature: 75.0*C
                Temperature: -2.0*C
                Voltage: 13.589 V
This time around it looks like the CEL came on for the P1128. I’ve got this code intermittently since I put on the JHM intake manifold 2? years ago but always seems to pop up when its cold. I cleared the codes the 13th and have checked every day since with no codes coming up. My question is how concerned should I be about the timing code? At some point I planned on doing a timing service but I was hoping to wait until at least this summer or beyond when I have time to do it myself. Thanks in advance…
