2012 S5 4.2 6mt sport diff-
I have 15k on my car and decide to head out to sears point/infineon/sonoma raceway/whatever they wanna sell out to this week.
practice pass #1:
headwind pushed me back out of staging and red lighted me=no ET
practice pass #2. I stage quickly, set electric parking brake, disable traction control and depress the throttle, knowing that the car hold revs just under 4k. ugh, except when electric parking brake is on. so as the lights are cascading downward and lower the revs by ear…and dunno what rpm I launched at, but seeing the tach fly to the redline wasn’t expected when assuming launch rpm limiter would be on.
2.05 60’
5.81 330’
8.891 660’
11.512 1000’
13.738 et @101.36mph
practice pass#3
I forgot to turn off traction control.-yeah, I’m slow in the head!
apply electric parking brake
launch at 3k-learning the car…
it bogs, ugh!
2.315 60’
6.103 330’
9.180 660’
11.797 1000’
14.013 E.T. @101.82
mph is there, just not capturing it
practice run#4
traction control disabled
stage quickly, apply parking brake
set revs to 4k and launch- tires light up for a brief moment-
after engaging second gear, the revs slip up to 6k for a little over a second, then drop down and I realize the clutch wasn’t holding. don’t ask, I do know to remove my foot from the clutch, ok.
2.082 60’
5.864 330’
8.96 660’
11.595 1000’
13.827 @ 101.16 mph
capturing the car’s potential a little better, but know what i have to do. lower rpm on launch
round 1 of elimination
I noticed the headwind died down, so I changed my dial in from 13.7 to a 13.65
stage quickly, set parking brake, brought revs to 3500rpm and launched-no bog, tires didn’t light up, had a touch of the good wheel hop that my old buick used to have when the launch was ideal.
1.966 60’
5.643 330’
8.684 660’
11.27 1000’
13.491 et @100.15 broke out by a bunch
I dabbed the brakes because I had my guy beat, but I’m still learning my car’s laugh delay and so I was cutting horrid reaction times which you can’t do if you want to continue into the rounds of elimination. my guess is that my mph would have been a touch higher, but the smell of my roasted clucth after the last two runs will prevent me from going back out there until I figure out why my clutch is slipping from the first to second gear transition, as in it won’t hold second upon fast clutch pedal engagement. again, I know what I’m going and I’m not speed shifting!!!
I’ve rearched the forums and some people are blaming a delay valve that is conducive to super plush clutch engagement, but needs to be removed if I want to drag race.
to me, past experience has brought slipping clutch issues in final gear-as in 4th on a four speed trans, or fifth on a 5 speed. those gears have the highest resistance against the engines.
any insight, even from “pinkberry” ?
