here’s a question…has anyone ever considered the 6500ish RPM shortshift is actually a good thing?
The stock tune basically goes flat in higher RPM. Maybe the car, in sport mode, is trying to get you to shift at an advisable time in the power band.
Clearly a car that is tuned makes power to redline, but cars that are not…don’t. The stock transmission program doesn’t know your ECU is tuned…so maybe in certain situations it knows you’ll be faster ‘short’ shifting at 65. Further, even though you are making power to redline, it doesn’t always mean you should push the car right to it.
The B5/6/7 S4 all benefited from shifting before redline (usually about 500 rpm before). While you may be gaining SLIGHTLY to redline, even you tuned guys, I have never heard anyone on these forums talk about optimal shift points…seems everyone assumes you just blast to redline and if it doesn’t work, you get upset. If the MT6 guys can go to 7200, you assume they have an advantage.
Some of the worst quarter mile times, relative to their modlists, in the B5/6/7 world came from guys who pushed every gear to redline.
Here: this car should NOT be pushed to the redline. IT’s screaming ‘shift me!’ in the low 6000 range.
Here’s an APR tuned car with pulley. This isn’t exactly an aggressively positive slope to redline either…
