So my clutch pedal is still sticking on WOT pulls.
Slave cylinder has been replaced
Master cylinder has been replaced
Line between the master and slave has been replaced with a ss braided line
Clutch assembly has been taken apart and put back together again with the release bearing replaced at that time.
Lines have been bled and flushed many times.
After all that, the pedal is STILL getting stuck after a WOT pull. I have to pull it back with my foot. While it’s stuck, there’s one inch of travel and in that one inch, the clutch is working just fine (i.e. grabs perfectly well). As I pull it back with my foot, it springs back into place and everything is fine again. In other words, it doesn’t sound like it’s a hydraulic issue (the pedal never feels soft and when it comes back from me pulling with my foot, it springs back just fine). It just gets stuck near the flooring (an inch away) and stays there but only after WOT runs. Normal driving is perfectly fine.
I’ve given up as to what the problem might be. No one else seems to be able to figure it out either.
