slow4, Yes it is a lot easier this time around. I can’t wait to fire it up too.
justincredible, Thanks. Yeah, most people that I try to explain all this to are lost after the first sentence so I can only imagine.
badger, Those are some nice trays especially since you can adjust them for different sized bolts. I have seen people use plastic baggies, ice cube trays, and all sorts of things to stay organized. I like magnet trays for loose bolts and nuts if I can’t screw the fasteners back into whatever they came out of.
BCsniper, Your getting there. What wrap did you use?
Over a few days I have done some more work on my S4.
Got the center differential, selector shaft, detents, and the reverse light switch cover of the transmission all reinstalled.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0498_zpsw7k80bnp.jpg
Put the components that go inside the bell housing back in.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0497_zpszc2difmi.jpg
Installed a new rear main seal and then reinstalled the JHM lightweight flywheel and 5R clutch that I have been running for a while.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0495_zpsyvw7r1lq.jpg
Then I installed some JHM secondary air injection combination valve block off plates. They are the little black pieces. The secondary air injection system is coded out on my car since the pump had to go to make room for the supercharger. I wanted to remove the valves so that the engine is a little easier to work on for certain things. It also helps that the emissions inspector up the street from my house doesn’t even know what a secondary air injection system is, much less what the components look like.
Driver’s side:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0494_zps53cprq5g.jpg
Passenger’s side:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0493_zpsb6l0ouyc.jpg
Then I reinstalled a lot of stuff with new gaskets and seals like the intake manifold with tapered intake spacers, the rear coolant pipe, oil filter housing, PCV valve and hoses, the valve covers with a fresh paint job, transmission, and the starter. Also replaced a bunch of sensors like the oil pressure, engine coolant temperature, both camshaft position sensors, and the crank position sensor.
Front view:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0499_zps7nc1zpl1.jpg
Driver’s side view:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0500_zpsgi1xazpu.jpg
Rear of the engine view:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0501_zps4fu0odyb.jpg
Passenger’s side view:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0502_zpsoeteagi8.jpg
In addition to the rest of the engine work I got the version 2 JHM headers. This is a comparison picture of the version 1 JHM long tube headers that I had and the new version 2 JHM mid-length headers. The new headers have shorter primary pipes that are slightly bigger in outside diameter. Both sets of headers are ceramic coated on the outside and inside, the version 1s are coated with Eastwood Company ceramic coating and the version 2s are coated with Jet-Hot extreme 2000 degree coating.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0511_zpsb8mrggeh.jpg
Not only are the version 2 headers ceramic coated but I am also wrapping them with Heat Shield Products Inferno header wrap. I am doing this for maximum heat retention inside the pipes to keep the heat out of the engine compartment that doesn’t have much air flow to begin with. It took forever to wrap the headers but I think that they look pretty good.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0515_zpsx7bbrrkx.jpg
Then I moved onto wrapping the mid-pipes for the version 2 headers. I ran out of header wrap after wrapping the one mid-pipe and then a little bit of the second mid-pipe. That is 200 feet of header wrap (100 feet of 1 inch wide and 100 feet of 2 inch wide) between the headers and the mid-pipes and a shit ton of stainless steel cable ties or thermal ties.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0514_zpsx9tqkd0f.jpg
