I thought you guys might like to see this too.
Since I got my current S4 I have been enjoying every few minutes that I get to drive it on the street, at the track, and sadly on the tow truck home. Over the few times that I have taken it to the track I have broken a few things and I thought it was time for some upgrading. Here is an old bad cell phone shot of my car lined up at MIR waiting for the Monte Carlo:
http://i284.photobucket.com/albums/ll37/Jimmybones777/S4atdragstrip.jpg
Since going to the track a few times I have done a some mods to my car, mostly for stuff that I broke like:
-USP metal slave cylinder with SS line
-JHM light-weight flywheel with stage 4 clutch
-Stern race density engine mounts
-Wavetrac LSD rear diff - I broke another rear LSD that I tried
The other stuff that I have done to my car was just because it was easy to do at the time or I was already in there for other maintenance like:
-JHM Trio package
-JHM 4:1 center diff
-JHM light-weight crank pulley
-034 Motorsport race density transmission mount
-Apikol snub mount and race density rear diff mount
Currently my S4 has been sitting down with the front end off for a few months while going through a couple of my projects that will be posted up later on as I get them finished. Now since I had the front end off and valve cover gaskets sitting around I thought it would be a good time to replace the leaking gaskets and clean the oil off my engine.
http://i284.photobucket.com/albums/ll37/Jimmybones777/mycleanedengine1.jpg
After a little paint I put the valve covers back on and here is the passenger side back on.
http://i284.photobucket.com/albums/ll37/Jimmybones777/mycleanedengine9.jpg
Yesterday, I got a package from 034 Motorsport for my recent order with JHM with a bunch of goodies.
http://i284.photobucket.com/albums/ll37/Jimmybones777/suspension2.jpg
Starting from the middle then going out. There are 034 Motorsport front sway bar end links, strut mounts, fully spherical adjustable front upper control arms, and spherical front lower control arms. The coilovers are KW clubsports that I got from 91gl a while back.
This is a blurry shot of the front struts with the upper control arms and the dust boots installed. Let me tell you the dust boots can be a PITA to get on.
http://i284.photobucket.com/albums/ll37/Jimmybones777/suspension5.jpg
Most of the parts I am taking off will be posted up in the classifieds section when I get them off the car.
So far this is all for now and I will keep updating this thread as other things come in.
- good luck with the install!
