JCviggen's misano B7 RS4 - work in progress
Sorry, I misread that.
Show me a C6 RS6 that is slower please.
[quote]It’s not the strips that are the problem, it’s the bazillion other variables which aren’t shown. I mean, if we went by the certified© times in your list we see that one car with a JHM tune trapped slower with the tune than on the stock ECU. That’s the only certified part. At face value, the JHM tune did barely anything on Mistro’s car at the track. You need the piece of information about atmospheric conditions and so on but these variables are MIA, others are even more difficult to quantify. Even playing with tire pressures can influence terminal speeds quite a bit.
worrying about ‘a bazillion other variables’ is a common refrain when attempting to plug one’s ears. However when you’re comparing dozens of inputs, and they keep telling the same story, it’s pretty simple.
Pointing at that one piece of data (which I have explained to you, since I was there that day…my car went 12.81 @ 109.9) and saying it invalidates all of the other data is again, convenient, and a bit argumentative. What you’re trying to do is not listen. That’s fine. I presented the thesis that the JHM RS4s are faster than all of the competition. You attempted to knock that down for no reason other than to knock it down. I have dozens of examples of acceleration tests, be they 3k-8k speedo checks…3k-8k VCDS logs…Pbox data…dragstrip data. You don’t accept any of it, and that’s fine. I’m not gathering the data to sell tunes. I’m gathering the data to help our community. If you want to buy something else, that’s cool. A couple of of RS4 owners who have done this research and testing presented the JHM tune as a great option for you, and you decided to instead have someone else tune your car. Good stuff. But don’t try to knock down what JHM modded cars have accomplished because it doesn’t line up with your plans.
[quote]What? Shift times are the deciding factor for buying a car now? That’s the silliest thing I’ve ever heard. Besides, I can shift plenty fast but my gearbox needs a rebuild first. I’m not going to grind it to bits to save two tenths on a glory run. Only point was driver makes a difference and it’s not small.
driving fast is easy. I don’t have any magic up my sleeve so save it. If you granny shift to save a few dollars over the long run, that’s your prerogative…but don’t project your granny shifting prejudice on the rest of the RS4 community. I can promise you that people who go to the dragstrip do not share your granny shifting techniques. They are trying to see how their car accelerates often comparing to stock stats they 've seen posted. When periodicals are testing the B7 Rs4, they aren’t granny shifting. When Audi presents performance data, they aren’t granny shifting. If you do, again, that’s your choice. However you’re in a very small minority.
[quote]The first part is special pleading, the second is outright false. MRC use a CARTEC dyno which uses measured coastdown losses. My C5 was on one identical to the UK one in Paris when it got mapped and you get all the data you want. The owner should have the print out with all data.
I think you should spend some time talking with someone who operates one of these dynos. The user inputs influence every single number that comes out of it. And yes, that includes the calculation of drivetrain loss on rundown/coasting. You can download the operator’s manual from Cartec-Snap On to see how to run the MRC dyno, as I did a couple of years ago. Interesting stuff. It may still be there.
[quote]I’m not discounting anything, I am saying it is incomplete. Yes you have 7 or 8 cars with JHM software. How many data points do you have for MRC, MTM, tunetec, sportmile, … ?
You have no basis to dismiss other tuners (yet) that’s the reality of it. And, again, ECU tuning isn’t magic. It’s hard work. Those companies who specialize in a few of these RS models all know what’s going on. If any of them would stumble onto a vastly superior approach they’d all know about it soon enough. I could order several tunes and post up the precise changes they all make to the mapping, if I wanted to waste a few grand on an internet debate.
Actually that’s not the case. My point about you dismissing our data was to show that no matter what you’re presented with, you’ll dismiss it. You did exactly that. You talked about all kinds of variables…tried to reference driver skill…all of the usual stuff people mention when trying to discount quarter mile data. As I have already said, I have acceleration data from many tuners. GIAC, APR, JHM, MTM, EPL and all of the supercharger companies. Our dragstrip list here has pretty strict requirements to qualify. That’s why that list is as it is.
As for why more people from other tuners don’t go to qualified dragstrips, that is a question that answers itself. For many of them, they don’t like other people controlling the ruler. They like using their own ruler. They then come up with a load of excuses as to why they don’t go. You’re familiar with most of them, as you’ve used them here today.
Who put the wrong plugs in again? The guy who is going to tune the car?
Also the same guy who is afraid to open up the transmission, which with the right manual also isn’t “rocket science”
ETKA says they’re the right plugs. Trust me I spent more time arguing with him over plugs than I have with you over ECUs and I had to admit defeat. They came in an Audi box and the part number was validated for the B7 RS4 by Audi themselves in the latest ETKA. My older ETKA version had different Bosch plugs. I’m not sure even Audi pay attention to this stuff, it’s all beancounters.
There’s NGK and Bosch in ETKA, 50/50 which you end up with unless you specify. Also, we’ve not actually determined yet that the plugs were to blame. But I wanted to at least remove that variable for the sake of troubleshooting.
help me out…is this right?
  1. your mechanic puts the wrong plugs in the car along with a whole bunch of stuff
  2. the car then had a bunch of misfires and stuttering/stalling at low RPMs
  3. despite that it still ran faster than any measured stock RS4 in history from 3k-8k…while ‘crabbing’ around the slippery road no less
  4. that same mechanic then traced the problem (that we know he created with the wrong plugs) to a ‘faulty fuel injector’ which was replaced
  5. the mechanic who put the wrong plugs in the car, and is scared to do a transmission rebuild (which has been done by a bunch of members on this site lol) is now going to tune it as well!
  6. that same mechanic/tuner jacked up your rev limiter to 8500 for no good reason (it actually makes the car slower going that deep), with no improved internals to handle the increased speeds. Audi completely revamped the high revving 4.2 FSI for the B8 RS4/5 to handle the new higher 8500 rpm rev limit.
  7. that same mechanic then put the correct plugs to fix his mistake and the car is back to running normally
Can’t wait for the performance testing and running the car to 8500 RPM! If you start seeing blue smoke coming out the back after a while, don’t worry. I’m sure it’s nothing. If you need a new engine, contact Flying Tomatoes. He has the market cornered.
http://www.youtube.com/watch?v=mkm_2l3qfZM
C6 RS6: ~13s
C7 RS6: ~12s
RS4 downhill hurricane: ~10s http://www.youtube.com/watch?v=3N_C3jz42X0
How is it telling the same story? I used an exact piece of data from your collection which showed nearly identical trap speeds for Mistro’s car with and without the tune.
The other variables are the only thing you have to claim a big gain on the tune in this case.
[quote]saying it invalidates all of the other data is again, convenient, and a bit argumentative. What you’re trying to do is not listen. That’s fine.
I’ve not said it invalidates anything. I’m saying a lot of info is missing. Info which makes a huge difference in the actual results, as this example shows better than anything else.
[quote]I presented the thesis that the JHM RS4s are faster than all of the competition. You attempted to knock that down for no reason other than to knock it down.
Because your thesis is not well supported. Explain me how you can claim something to be faster than all of the competition without actually presenting meaningful data on said competition? It just doesn’t make sense. Where is the competition in your spreadsheet? A single GIAC chip? (which did pretty well actually) A single MRC car? More Audi tuners exist on this planet that are not on your list than those who are…
[quote]3k-8k speedo checks…3k-8k VCDS logs…Pbox data…dragstrip data. You don’t accept any of it
I can accept things which I can see. Just claiming something exists and presenting it isn’t the same thing. I’m having a hard time finding many 3-8K runs and would absolutely genuinely appreciate seeing them in order to learn more.
[quote]A couple of of RS4 owners who have done this research and testing presented the JHM tune as a great option for you, and you decided to instead have someone else tune your car.
I thought I explained this already. I’m months from being able to get a proper tune. I don’t know if I’ll get a tunetec, MRC, or JHM. If I try multiple tunes I’ll probably get a tunetec or MRC and get a JHM cable which I will only use after I’ve extracted the other tune I paid for so I don’t lose it when it gets ovewritten.
I do trust Dmitry with ECUs and he’s removed the torque limiter for me and stopped my exhaust valves closing in S mode. For peanuts. It’s not going to be the final tune no matter what. Just to be clear here.
[quote]If you granny shift to save a few dollars over the long run, that’s your prerogative…but don’t project your granny shifting prejudice on the rest of the RS4 community.
Nursing a temporary mechanical issue isn’t a life philosophy. You can tell just by listening to quarter mile runs how quick someone manages to shift and yours are quicker than most. Certainly faster than the UK bloke’s video I saw.
But you can see the number. It’s not hidden. And if it falls within the expected range, there’s nothing more to argue. My car had 126 PS loss on the stock map and 105PS loss once remapped. Losses went down, not up. From my experience with MAHA and superflow coastdown results the figures are absolutely realistic.
But yes, they do read a bit high generally. I’d say 25 BHP too much at 500.
[quote]My point about you dismissing our data was to show that no matter what you’re presented with, you’ll dismiss it. You did exactly that.
I’ve not had a chance to dismiss relevant data. That’s prejudice right there :wink:
And I have not dismissed anything. I’ve called it incomplete and useless as proof for comparison as most things you’d want to compare it to are missing.
As long as they are missing, you’re not anywhere close to proving something logically. And I’m not the one making a claim, you are. The burden of proof is on you. I’ve not dismissed any of your proof, I’m waiting for you to show me the rest of it. If it exists.
See above. They’re right as far as Audi is concerned. How can I blame the guy for following ETKA?
[quote]2. the car then had a bunch of misfires and stuttering/stalling at low RPMs
It hated low loads when cold, yes. Misfires, yes a few. Stalling, no. I’ll see tomorrow on a proper cold start if it’s all good or not. SW0090 also addressed specifically cold running issues so it may be a factor as well.
[quote]despite that it still ran faster than any measured stock RS4 in history from 3k-8k…while ‘crabbing’ around the slippery road no less
I don’t know if it was faster than any stock RS4, I don’t think other cars running normally at 380-390 or so horsepower wouldn’t be able to do it at -8.5 Celcius. It didn’t feel unusually quick. Some people got pretty close times in ambient 25C higher so…
In any case I’ll try my best to replicate it ASAP with that lovely accurate timer running on the dash.
I really don’t want to interject in the debate, but from my reading of your posts, I have to agree with what euro said:
Sak has provided you with facts and data, yet you keep insisting that his burden of proof hasn’t been satisfied. You’re essentially arguing for a “beyond a reasonable doubt PLUS” standard. That strikes me as unreasonable. The burden has shifted, and it’s now on you for a rebuttal.
It’s good to hear that you might have gotten all this sorted out with your car. It sounds like it was a bad injector.
As for the ecu debate. I have a few thoughts a few opinions and then facts.
My thoughts are. You saying that people are sensitive about jhm and your no into religion reduces my belief in your knowledge of the performance aspects of the rs4. As testing has been done and hands down for years now jhm is the fastest and best performing tune by far. My reduced believe in you gets worse when you say tuning isn’t black magic and it’s not that hard. Actually continued proof that not each company can tune keep coming up again and again. The proof is shown in all aspects.
The last nail in the coffin for my thoughts on your over all understanding of performance is the fact that you said you can’t call jhm the best company for performance even tho they have almost all of the top 10 fastest tuned cars and the list goes deeper. From proof on the track and proof on the street and proof on the dyno. Jhm beats all hands down. Your argument if I understand it is you can’t call jhm the best because everyone else hasn’t been tested…
That falls apart because most others have been tested and we have seen the results and just how far behind they are when compared to jhm. Saying some obscure company MIGHT BE BETTER…might might might. But they can prove and can be proven if they wish. The proof is that cars tested show jhm faster by a long shot. If all it takes is not testing and proving or providing proof that my tune is faster to still consider my products good. I’ll start a company tomorrow and never test our cars. I’ll then say you can’t say I’m not the best because nobody has tested my products.
The fact shows results and results show jhm is faster. That’s the facts. The collection of car owners started demanding standardized testing and that testing is the 1/4 mile. That distance is always the same and time is always a constant. Each company has the ability to test and show there ability. The B8 S4 guys have not taken thus to the next level and have essentially proven quite well that not all tunes are equal and just buying a tune off a dyno sheet is a terrible idea.
You can have different standards if you wish for proof. That’s your choose. Lots of people have gotten ripped off by spending 2000 dollars on intake setups for there rs4 that MRC said made power in the dyno and MRC sold them. The problem there is we showed they actually don’t make more power. So to call people who believe in a company that not only makes products but tests them to prove the products worth. To call those people part of a religion is fine but know that religion is one that has the highest standards of proof.
I’m not going to spoonfeed you the information we’ve seen over the years because you bought an Rs4 this month. Again, I’ve already said it. You won’t be convinced of anything, no matter what anyone shows you. I am sharing what I’ve seen, and I have no dog in the fight. I have a used JHM exhaust on my RS4, and nothing else. I have however done loads of acceleration testing. If you choose not to believe what I’m telling you, again, that’s not a concern to me. If you were here for the past 4 years learning along with the rest of us, you wouldn’t need to be spoonfed…you’d know what everyone here already knows.
[quote]Nursing a temporary mechanical issue isn’t a life philosophy. You can tell just by listening to quarter mile runs how quick someone manages to shift and yours are quicker than most. Certainly faster than the UK bloke’s video I saw.
no, it was your assertion that the strength of my results or mistro’s results or all of the JHM modified car owners’ results can be explained by our incredible dexterity in the driving seat because we are all supershifters…and all other drivers from GIAC/APR/MRC/PES/AMD /UM tuned cars are ham fisted clods who don’t know how to drive.
CHECK!
[quote]But you can see the number. It’s not hidden. And if it falls within the expected range, there’s nothing more to argue. My car had 126 PS loss on the stock map and 105PS loss once remapped. Losses went down, not up. From my experience with MAHA and superflow coastdown results the figures are absolutely realistic.
When you buy a Cartec Snap On dyno, and set it up, you have to give it a bunch of inputs that influence the drivetrain loss. You can make it read whatever you want. That’s my point. I was suggesting downloading and reading the technical manual to see what I’m talking about. It’s not a magic device. It takes a load of inputs from the operator to determine outputs. Many dynos are the same.
So I only read a little bit of this but I was already asking myself “Is this guy an engineer or something”. Why would I ask myself this question? Because the most irritating “friendly” arguments I’ve ever had have been with engineers. I think as part of the degree, they are required to be a member of the debate club as well. Engineer + debate club = just tell them they are right and move on (they already know they are anyway).
And with that post. I have to agree. Welcome jeff33702
No they assume they are always right and set an impossible criteria for proving them wrong…therefore it’s impossible to prove them wrong.
Notice his reference to “beancounters” this is funny because the only thing that can stop and Engineer is budget or $$, not someone telling him his design is flawed or failure rates are off…especially some guy who isn’t an engineer. No matter how much hands on experience or real world knowledge you have, you will never convince him that it won’t work or will work poorly, you just have to take away his funding.
Can you kindly link me to where this data has been provided? I’m at a loss as to how I must have overlooked it.
I have seen a lot of data suggesting that JHM’s NA tunes are good. I’m not saying they aren’t.
Sample size of the 1/4 mile list:
Stock - 10
JHM - 6
GIAC - 1
APR - 1
MRC - 1
REVO - 1
MTM - 0
Tunetec - 0
I’m sure some of you remember statistics in school and understand that a sample size of 1 or 0 is statistically useless.
Furthermore there is only 1 car in the entire list which actually has results both stock and mapped. That further makes correlating results nearly impossible.
Still, if I could ask one question it would be how exactly you guys manage to discount or eliminate tuners for being inferior when there is literally zero recorded (visible) data on them? And after that I’m being accused of bias…
Back to the matter at hand, and my annoyingly fast stock car, I talked to Dmitry and I’m currently on a completely stock Audi map. Just a later version. To see what it does first before I go in to get a new injector (which had to be ordered, not in stock in any Audi dealer in Moscow)
Did it in both directions, on the embankment of the river (so it should be pretty damn close to level)
No wind to speak of, ambient +2.5C.
Stopwatch on the dash: 7.9/7.9s
From video analysis: 7.95/7.95
Throttle body at 52.5% in VCDS until 5500+
http://www.greenringer.net/various/arthurtest/VIDEO0089.mp4
http://www.greenringer.net/various/arthurtest/VIDEO0090.mp4
Actually got lucky to find space for 2 opposing runs because the short bit of road I do this on is a bit sketchy traffic wise. Finding a spot that allows 100 mph in the middle of a metropolis known for its traffic problems is a challenge and a half.
J
to be honest I haven’t even heard of tune tunetec and as sakimano said. While the list might not show times we have seen a deeper pool then what’s made the list.
Frankly if you want to be considered great at something the burden of proof is up to the company’s. So you can say you don’t have enough results from random obscure company’s but that just further shows jhms commitment. They go out and prove the product works. Most of the others just put out a dyno sheet that has zero standardization and tell people to look at that. We know dyno results are bs those sheets have been lieing to people for years.
To me and obviously the others. To be considered great you have to do more then just put out a dyno sheet you need to prove your great. Jhm consistently has done that and it’s been backed up by its customers. Further more jhm has a history of great and dominate performance over other but specifically in the NA tuning
The reason you don’t see too many other times on the list from other company’s is people have figured out who the best company is for performance (jhm) so they don’t waste there money on other tunes.
The other company’s that don’t have times on the list loose by default. If they want to be considered great by the people here they have to do something to prove it. Other wise they are just like every Sunday arm chair footballer saying how great they are but not going into the field to show it. If a tuner isn’t committed to putting there tune under the requirements of proof they just aren’t committed to these people’s support
Do please keep us posted on your cars health. It was a great idea to keep the variables to a minimum when trying to chase down an issue.
I’m completely with this on the US side, if I was there it would be a no-brainer.
But I personally don’t know anyone with a B7 RS4 in Europe who is on a JHM map. I’m sure there’s at least one somewhere but point being it’s a different place with different tuners. The reason you don’t have results is because hardly anyone ever does quarter mile races here.
I’ve actually noticed one peculiarity in Sakimano’s list which has me a bit puzzled to explain mathematically.
sakimano stock JHM 2.75" 12.51 @ 110.48 1.8 60ft
Badtoyz JHM JHM 2.75" 12.53 @ 112.12 1.82 60ft
sakimano stock JHM 2.75" 12.53 @ 110.53 1.82 60ft
Gavla MRC piggies/2.5" 12.54 @ 109.79 1.82 60ft
The 60ft times are identical aside from the first which is 0.02 faster.
The quarter times are, near as makes no difference, identical as well. How come the trap speeds are so different?
Saki 1 spent 10.71 seconds over the 1260 feet remaining.
Badtoyz spent 10.71
Saki 2 spent 10.71
Gavla spent 10.72
Basically, they took exactly the same time to complete the course which means their average speed over the entire run was identical. Yet between best and worst you have 2.33 mph difference.
The only thing I can think of is headwind/tailwind/differences in drag. Which would affect the end of the run more than the beginning. But it also means that the slower trapping car MUST have actually been going faster for some time after the 60ft mark than the faster trapping car. Otherwise they wouldn’t end up with the same average.
I don’t know about you but I think it’s fascinating, and shows that there is a lot beneath the surface of these numbers.
Faster shifts and more time accelerating can make a car quicker than a faster car…if you can divulge that horrible explanation, haha.
Saki, has proven to be a pretty awesome 1/4mile driver/shifter.
The JHM tuned car is trapping faster because it is probably making about 20 more hp than all the others. Badtoyz may have not been the better driver out of the bunch in this comparison, but the extra power from his JHM tune allowed him to match the better drivers ETs and in reality he should have ran about 2 tenths quicker than the others.
(Before you beat a dead horse, YES there may have been other outside variables like you’ve mentioned, but the above is the most common reason you see instances like this in drag racing)
None of the members here will argue that the 1/4mile doesn’t have variables, but by looking at a full time slip we can pull a lot of acceleration data and make some pretty neat comparisons. We are by no means scientific to the extent that you want, but you can’t argue that the data isn’t useful.
Not sure you understood what I meant. The 60ft times are identical. Which means they launched equally well (the hardest part by far)
The average speed from 60ft onwards was the same for all cars. Which is like measuring 25 to 110 mph I suppose. The only way you could end up with a higher trap speed but the same average is if you were slower at the beginning. But we know nobody was really slower after 60ft as they were identical. You can’t cut an identical 60ft time without having the same average speed the first 60ft.
Could be down to slow shifting, yes. But you can turn it around and say the MRC car was being driven poorly or it would’ve had a similar trap speed and an even faster ET. See? You can’t tell the difference from the data at hand. Which was my point from the beginning. Big conclusions are being drawn from data which doesn’t support it.
